Threads: 87
Hey guys, in Florida I live in a condo with no access to a private garage so I keep my CB at a local storage unit. Since I've kept the bike there, it's been plugged in and on a battery tender. I don't ride much in the summer...way too hot, but I do manage to get out at least once every month or so; more so the rest of the year. I just had to move to anther storage facility however this one doesn't have power so at present the bike is not plugged in. Does anyone ride their bike infrequently like me and not keep it on a tender? Have you had any issues? I keep my other two bikes at my home in Georgia and they're on a tender. But I do keep a car up there that is not on a tender and I've yet to have any issues. What do you think? Am I just waiting for trouble here with the CB?
Threads: 85
Likes Given: 133
After my accident my bike sat off a tender for about a year or so. When I went to fire it up there was no issue at all. Turn the key on, prime the pump, hit the start button and she fired right up without missing a beat.
Likes Received: 616 in 276 posts
Likes Given: 788
R4N it used to be that a battery not on a charger would lose about 1 % per day, so in 30 days it would lose 30% of its charge, in 90 days 90%. I don't know if that is true of these new glass mat tech batts. The problem being with not keeping it on a charger I think, is that batteries dont like the cycle from low charge to full charge, back to low charge etc, and it probably wont last as long as one well maintained and kept near full charge. I do know that once these glass matts go, they go instantly. Start one time, flat dead the next time you go to start it. There doesnt seem to be any warning that your batt is on its way out. They are either good, or shot it seems.
I am not a battery tech just going by what I have been taught and what I have observed from years in the business and personal experience.
Others I am sure, will have a different opinion and life experience.
Threads: 78
All these modern bikes have a constant current drain. I keep all my bikes on some kind of tender. The batteries will go flat. The trickle chargers are inexpensive. No good reason not to use one unless there isn't any power available.
Once a month should be more than enough to keep it charged up as long you get out for an hour or so at a decent cruising speed.
Threads: 22
A Lithium ion battery may be in your future. Expensive battery but specifically for long term storage applications.
Likes Given: 91
My bike sits for two weeks at a time or longer without the benefit of a tender. I don't really think you'll have an issue. However, how about keeping a spare battery on a tender at your house and bringing it with you when you go to pick up the bike?
Threads: 23
I would just make it a point to ride it a little more, even if you don't want to. Or you could hire a bike walker, kind of like a dog walker, lol. Someone who can take it out for you once a week. I'm sure you would get plenty of offers, lol.
Sent from my SM-T350 using Tapatalk
Threads: 39
I also live in Florida and ride all summer but mostly early and late during the very hot days. but all my toys have tenders and the batts last so much longer . even have a 6volt on my 48 GMC and one on my lawn mower
have you considered =
http://www.harborfreight.com/15-watt-sol...68692.html
Threads: 36
About a year ago the battery unexpectedly died in my car, and I bought an item similar to this. It jumps my car if ever needed, but also has a 120 volt outlet to plug in any item desired. If I was in your situation I would buy something similar to this, full charge it at home, then put it in the storage unit with my bike with the battery tender plugged into it and attached to my bike's battery.
https://www.amazon.com/Rally-Portable-So...TAS2CWKGYZ
Threads: 1
If it starts no problem with once a month use,just resign yourself to buying a new battery more often than you would if it got regular use.No big deal,just a little extra expense,be careful of solar charge setups,they need charge regulators and blocking diodes to prevent reverse current discharge when the sun goes down.Overcharging will probably kill it sooner than low usage.
