CB cuts out while riding
Aren't our US bikes all 50 state bikes? Have to check my sticker again when I get home.
I think California bikes are different. Mine has no evaporative recovery system far as I know.
Bike I just bought - one-owner from New York, is a 50 state bike, with a California Emissions certification on it.
Rode to work this AM in cooler temps with no problems. Bike ran fine! I really did fill it about as full as you could get it then the metal tank sat in a hot sun for several hours in the low 90s. Won't be doing that again.
BayArea and Redbirds, I'm pretty sure they all have the evaporative recovery system (US at least). Have to do some looking in the service manual and at my bike.
Frulk, glad to hear you bike is ok now!
I usually only fill to the bottom of filter neck but I have over filled, Heck, I once filled it to the very top, (by accident) I never had a problem..... I also gave up on 91 octane, 87 does just fine.
Sent from me......
(07-26-2016, 02:13 AM)Lord Popgun_imp Wrote: Aren't our US bikes all 50 state bikes? Have to check my sticker again when I get home.
These days I don't know. CARB has its own set of regulations.
I know for some time a number of bikes were made 50-state because so many were sold in California. Which ones they may be, I can't say.
Redbirds, go to the right side of your bike. Right under the plastic air box cover is a bracket. Look under that bracket and you will see the canister behind the bracket. Kinda looks like a longesh oil filter.
(07-26-2016, 09:08 AM)Lord Popgun_imp Wrote: Redbirds, go to the right side of your bike. Right under the plastic air box cover is a bracket. Look under that bracket and you will see the canister behind the bracket. Kinda looks like a longesh oil filter.
Went looking for it earlier and there it was. Looks like it would be easy to eliminate along with the air injection (pair valves).
Ok, last post from me on this issue. Rode back from work today with bike sitting all day under a blazing sun at 4,600 feet altitude and temps as high as 98 degrees. Started up fine. No sputter/hesitation. Didn't cut out/die. Ran like a champ all the way home for approx. 10 miles. Lesson learned. In HOT or even warm weather do not fill tank totally full on the center-stand.
  Forex Seen Fueling Some US Motorcycle Price Cuts sig_a_imp 0 175 04-05-2015, 01:00 AM
Last Post: sig_a_imp
