CB cuts out while riding
At lunch I went and filled up the bike as much as possible. Had a pump that had a really good slow speed flow which allowed me to put it on the center stand and trickle the gas and filled up the tank as full as I've EVER had it. Used 91 Octane as I always do. Drove back to work and parked bike for 4 hours. after work came out and bike was sitting in the sun and afternoon heat topped out at 93 degrees. Started fine and took off but about a hundred yards down the road bike started to stutter and just died. Turned starter over and it slowly started back up. Revved it a couple of times and took off again. Once more it cut out. Coasted off to the side of the road and opened tank to release pressure/vapor lock?. Started bike again and took off and kept the RPMs a little higher. Drove the 8 miles home without incident.
Thoughts on cause? Anybody else have this happen?
(07-25-2016, 01:26 PM)Frulk_imp Wrote: At lunch I went and filled up the bike as much as possible. Had a pump that had a really good slow speed flow which allowed me to put it on the center stand and trickle the gas and filled up the tank as full as I've EVER had it. Used 91 Octane as I always do. Drove back to work and parked bike for 4 hours. after work came out and bike was sitting in the sun and afternoon heat topped out at 93 degrees. Started fine and took off but about a hundred yards down the road bike started to stutter and just died. Turned starter over and it slowly started back up. Revved it a couple of times and took off again. Once more it cut out. Coasted off to the side of the road and opened tank to release pressure/vapor lock?. Started bike again and took off and kept the RPMs a little higher. Drove the 8 miles home without incident.
I wanted to comment on this practice of topping the tank while the bike is on the centerstand prior to this post, but didn't. Wish I had.
Some owners do it and will state it is no problem and allows the tank to be filled to the maximum, which is good as the tank is small and every drop counts.
If they've never had a problem, so far so good.
However, the tank was not designed to be filled while vertical. There is an air space in the top of the tank which allows for expansion and if the tank is overfilled, fuel can flow into the evaporative control system and disrupt fueling. Uneven running and stalling are the result.
Sounds like that is what has occurred with your bike.
If you have a California bike this may be much more likely.
Sometimes, allowing the bike to sit overnight will take care of it once the fuel is dissipated, but sometimes the evaporative control canisters and system need to be disassembled as there is liquid fuel in the lines.
Sounds like your bike cleared the system and is OK now.
Wow, I would never have known this. Very interesting. I do generally fill up whilst on the prop stand, but for sure will now avoid the centre stand when I fill up. Thanks for this info Tongue
You can fill it on the center stand, just fill it to the neck and don't try to pump a few extra tenths. I always filled my CB on the center stand.
Yes, its in the owners manual. Only fill to the neck. What Ulvetanna said can be the result.
Didn't we just have a member in France (I think France) that was gassing up and leaving the bike in the sun all day. He had fuel coming out the vent.
And the education continues. Thanks for the info!
One the center stand and filled all the way up th the very base of the neck should be fine, even when it's hot out. I agree with others here that overfilling is the likely cause of your issue. I had something similar happen to me when I inadvertentally overfilled my tank. It didn't stall out, though, it just ran rough for a while.
Also, I gave up on 91 octane because I actually perceived a reduction in performance on very hot days. Probably my imagination, but my bike runs fine with 87 and saves me a few pennies. Oh..I have the yoshimura exhaust with the catalytic converter removed, which could contribute, I suppose, to both the overfilling and higher octane issues.
If you are careful about it, and you ride the bike long enough to draw it down enough to restore the air space, this can work.
(07-25-2016, 09:22 PM)Lord Popgun_imp Wrote: Yes, its in the owners manual. Only fill to the neck. What Ulvetanna said can be the result.
Yes, I remember that. I'm pretty sure some US and especially CA bikes don't have that vent directly to atmosphere. State laws vary so I can't say for sure but a fuel tank vent to atmosphere is mostly a thing of the past.
I nearly always fill my bike on the centre stand and I've never had such a problem. Interesting information, though.
Good post and helpful responses. I, too, fill while on the center stand and am guilty of trying to get just a little more in than I probably should. Mine is a California model and I've never had a problem. Still, this is the perfect excuse for me to stop wasting time at the gas pump and to just be content with getting it to the bottom of the neck.
  Forex Seen Fueling Some US Motorcycle Price Cuts sig_a_imp 0 179 04-05-2015, 01:00 AM
Last Post: sig_a_imp
