Arrow Pro-Racing nichrom Silencers
Macduff_imp Offline
Threads: 11
RE: Arrow Pro-Racing nichrom Silencers
(08-11-2017, 05:48 AM)The ferret_imp Wrote: That sounds pretty raspy. Bet it sounds good at full song (always liked that expression)
I'm amazed you can take a video with a phone and post it here. Crazy world.
They definitely don't have that rasp listening to them by the bike. I gave it a bit of revs on a short ride and it didn;t sound much fruitier than stock though I suspect it is (a little) . They seem very much designed not to exceed homologated noise standards with the baffles in.
08-11-2017, 11:20 PM
Macduff_imp Offline
Threads: 11
Well it would appear that I can resist everything but temptation. Pulled the baffles from the cans, Very easy to do, the tang just snaps off with the flick of a small flat blade screwdriver , the baffles are held in with a large circlip which is relatively easy to remove if you have decent circlip pliers. Mine appear to be cheap nasty circlip pliers so kept slipping out before I got the clip compressed enough to remove (its large so fairly strong). ANyway after a few attempts the clips were out and the baffles were easy to pull with a light tug using some pliers.
Sound wise at idle is a lot deeper but not obnoxious , I didn't bother recording it as the mic on iPhone maxed out with baffles it wouldn't have coped with the airwave pressure increase without baffles. On the move its a lot more sporty sounding but still not obnoxious. Both my other bikes are louder and they either have original oem exhausts (ducati) or a UK BS stamped can (GSXR) though these are from an era when noise regs were a lot more relaxed (mid 90s duc, mid 80s Suzuki). Overall I'd say without baffles its probably sounds more like an 80s IL4 UJM would back in the 80s on the OEM exhaust, probably more like a Z1000 Kwaks as I recall the 80s CB(900) Hondas were still more silenced than the equivalent Kwak.
Anyway I'm glad its not obnoxiously anti social , will have to see how it ages.
08-22-2017, 04:58 AM
Macduff_imp Offline
Threads: 11
Last update (until something changes). I had fun being an oike for a week or so with the rorty CB but after riding in at a steady speed when I just wanted to chill and enjoy the scenery it was too much droan for my eardrums. So the baffles are back in. I suspect if a chap could be bothered the stock baffles could be tweaked for a little more sound either by shortening them or adding more holes, but I've better things to do with my time such as sitting on my backside posting crap on t'interweb.
09-06-2017, 04:27 AM
holy666diver_imp Offline
Threads: 37
fRemove the baffles you'll see a world of difference. How the heck will they know you removed the baffle?
09-07-2017, 04:10 AM
skidmarkart_imp Offline
Threads: 3
Dang, those are some good lookin' pipes.
09-21-2017, 05:07 AM
itstuantran_imp Offline
Threads: 7
I did some on my stock exhaust too. Gotta admit that stock exhaust is pretty quiet though. I was thinking about aftermarket exhaust options but then changed my mind and made some try on opening up holes, make the 3 available holes bigger instead of adding more holes. I have enlarged them up to 6mm instead of 4mm as stock, and it sounds abit better Smile. 9500km now and i'm happy with that Smile
(09-06-2017, 04:27 AM)Macduff_imp Wrote: Last update (until something changes). I had fun being an oike for a week or so with the rorty CB but after riding in at a steady speed when I just wanted to chill and enjoy the scenery it was too much droan for my eardrums. So the baffles are back in. I suspect if a chap could be bothered the stock baffles could be tweaked for a little more sound either by shortening them or adding more holes, but I've better things to do with my time such as sitting on my backside posting crap on t'interweb.
09-21-2017, 02:36 PM
Macduff_imp Offline
Threads: 11
Regarding stock exhaust on the '17 RS There doesn't appear to be an ( easy?) option for drilling holes to make more noise (not that I intend to do that), and to ensure I can get my oike fix for bike music I've just purchased a re-creation Yoshimura Cyclone stainless steel exhaust for my '86 Suzuki GSX-R750. This most likely means I'll leave the baffles in unmodified on the RS.
09-21-2017, 10:39 PM
Full Throttle_imp Offline
Threads: 0
Just curious if ear plugs would be enough to quite down the done to acceptable levels. I currently use plugs all the time, and was considering the arrow slip on.
09-22-2017, 03:44 AM
Likes Received: 640 in 285 posts
Likes Given: 800
ROFL love it... Put on pipes to make it louder, then plug your ears so you can't hear it
09-22-2017, 04:40 AM
Threads: 0
(09-22-2017, 04:40 AM)The ferret_imp Wrote: ROFL love it... Put on pipes to make it louder, then plug your ears so you can't hear it
Because loosing ones hearing is so much better good point. I can hear the stock exhaust while using ear plugs. some may want louder pipes for different reasons, other than just being an annoying rider to the public.
09-28-2017, 12:17 AM
  Arrow Slip-On Thoughts le_penseur_imp 84 5,908 05-15-2023, 05:20 AM
Last Post: mrded_imp
  Arrow exhaust. Mixagon_imp 11 1,006 10-25-2022, 01:56 AM
Last Post: ymtnpoah11_imp
  Arrow full exhaust gretle_2.0 2 369 05-17-2022, 11:38 AM
  loose the arrow jimgl3_imp 33 2,308 08-30-2021, 11:14 PM
  Arrow slip on mufflers DougsZ28_imp 15 1,319 05-13-2021, 04:09 AM
  Arrow full system exhaust tsmetjen_imp 19 1,538 07-29-2020, 03:46 PM
Last Post: tsmetjen_imp
   Over racing slip on spartanheed_imp 7 820 07-05-2020, 08:33 AM
Last Post: Cobalt23_imp
  Arrow Pro Headers Willmarth_imp 10 1,116 01-19-2019, 12:22 AM
Last Post: Tebs_imp
  R&G Racing Supermoto Exhaust Protectors apex1_imp 3 407 06-25-2018, 01:22 AM
Last Post: aschem_imp
  Arrow slip on, amazing! Kawiboy_imp 72 5,040 05-27-2018, 07:48 PM
Last Post: VAslim16_imp
