Gears Racing Shocks
camoto_imp Offline
Threads: 3
RE: Gears Racing Shocks
(11-14-2017, 08:56 AM)Mscb1100_imp Wrote:
(11-12-2017, 06:53 AM)camoto_imp Wrote: I had a nice opportunity today to really give these a good shakedown. Many of the roads around me are in bad condition and the stock suspension would really get out of sorts if you encountered the broken pavement in an aggressive turn.
I was really pleased with the improvement these shocks made. The bike is much more compliant now in situations where the stock shocks would be noticeably unsettled. I hate to use the word "plush" because it implies "mushy" to me, but I can say that I am no longer puckering or standing up slightly when there's a break in the pavement or a pothole. Most suspension components "break in" a little bit so I am expecting these to soften up a bit more but hopefully not too much.
One drawback of these is that it becomes glaringly obvious how lacking the front fork setup is when using them. Thankfully I already have the RT straight rate .90 kg/mm springs and 7.5WT fork oil here which I am expecting to make a positive improvement over stock in ride comfort and proper spring for my weight. If you have any specific questions please let me know!
Thanks for the update on how these perform.
Are they built to your weight or is it 1 size for all.
They only offer a single spring rate. I'm sure other springs could be fitted if you were outside of their design spec. You could email them and see maybe?
11-15-2017, 08:05 AM
BetterByCab_imp Offline
New to the Forum
Threads: 0
Thanks for stepping up and buying and making a report on these! It's this exact thing that adds so much value to this site Smile
11-21-2017, 02:44 PM
nhawk7504_imp Offline
Likes Received: 2 in 2 posts
"big bumps and quick changes of direction remind you why single-shock rear ends with more travel and progressive linkages killed off the dinosaurs" - John Burns, Motorcycle.com - '13 CB1100 - New England Pavement is basically a dirt road. Towns constantly dig up and patch roads for what lies beneath. Frost heaves. Manhole covers. Potholes. CB11 and CB1000R, both bikes hopped like Kangaroos on my (160 LB soaking wet) test rides. So these Gears shocks look like a nice refit.
11-22-2017, 03:13 AM
Desert viper_imp Offline
Threads: 7
Those shocks look great on your bike!
11-23-2017, 02:16 AM
peterbaron Offline
Likes Received: 594 in 325 posts
Likes Given: 1,003
VERY COOL pics and lookThumbs Up
...no matter what Japan delivers...bikers will always try to improve it to their personal satisfaction....sky is the limit...
pb
11-23-2017, 02:30 AM
rookallures_imp Offline
Threads: 1
Hey there camoto! Where did you get those drilled side panels?
Thank you!
11-30-2017, 01:59 AM
camoto_imp Offline
Threads: 3
(11-30-2017, 01:59 AM)rookallures_imp Wrote: Hey there camoto! Where did you get those drilled side panels?
Thank you!
I made them. http://cb1100forum.com/forum/showthread.php?tid=11652
12-03-2017, 12:16 AM
  Nitro Piggy Back Shocks touchetteweb_imp 3 408 03-29-2022, 12:39 AM
  Hagon Shocks: Response to Inquiry Huladog_imp 10 1,093 12-20-2021, 06:32 AM
Last Post: LikeAfox_imp
  New YSS shocks,Hyperpro Progressive front springs,gators ozigoo 10 983 10-03-2021, 04:03 AM
  ZRX Shocks( Probably Revisited) Rox_imp 3 407 10-30-2020, 12:16 PM
Last Post: IndianRider_imp
   Over racing slip on spartanheed_imp 7 806 07-05-2020, 08:33 AM
Last Post: Cobalt23_imp
  Amazon rear shocks DBM_imp 11 846 03-10-2019, 01:26 PM
Last Post: qmaven_imp
  Ohlins shocks for 2017 Houtman_imp 27 1,829 11-29-2018, 02:50 AM
Last Post: nhawk7504_imp
  Ohlin Shocks for 2017 Houtman_imp 4 450 09-02-2018, 03:02 AM
  R&G Racing Supermoto Exhaust Protectors apex1_imp 3 400 06-25-2018, 01:22 AM
Last Post: aschem_imp
  Moto gears header + BMS R-evo = good breathing itstuantran_imp 1 285 05-20-2018, 08:09 PM
