Heated grips question
Flytech99_imp Offline
Threads: 4
RE: Heated grips question
I just installed a set on my '14 DLX....
Honestly, it's not an "easy" job, but mostly because it's time consuming with lots of fiddly steps. There is nothing in the procedure that a semi-mechanically inclined person can't handle with the instructions and notes from forum members (which are INVALUABLE).
Full disclosure; I also installed a set of lower bars at the same time which made a few steps easier but complicated getting the throttle cables set afterward. That probably won't be an issue if you keep the stock bars.
Some things to keep in mind if you do it yourself...
Plan ahead and make sure you have all the supplies you'll need on hand, to include an extra fuel line fitting and rubber insert. Pulling the tank is a must and reusing the old connector probably isn't worth the chance of it failing down the road. Aside from removing the tank, getting the electronics tray out is the next part of the job that requires some serious patience. The rest is just time consuming and tedious due to poor illustrations in the instructions and limited access/clearances for routing the harness.
If all of this sounds like more than you'd want to take-on, my suggestion for taking it to a dealer would be to find a service tech that has done it before (on a CB or similar Honda). Better yet, get a mechanically inclined buddy to help you out. That way, you know the particulars are done right and you'll save some coin on labor.
03-18-2018, 11:09 AM
cookiemech Offline
Threads: 8
Likes Given: 1
(03-18-2018, 11:09 AM)Flytech99_imp Wrote: I just installed a set on my '14 DLX....
Please note that the OP has a 17 EX, which has a different fuel line connector at the tank (according to my service manual). The 17 EX fitting is all reusable, assuming that nothing has been damaged.
03-18-2018, 09:18 PM
Threads: 4
Ahh, ok! I wasn’t sure if that had changed. Probably a good thing then.... Hopefully the new fitting is a little easier to work with one hand.
03-18-2018, 10:11 PM
cookiemech Offline
Threads: 8
Likes Given: 1
I sure wouldn't call it easy . . . maybe the second time you do it, that would be the case! After consulting the manual a couple of times, then carefully removing it, it made a lot more sense to me. What was most important was moving the tank back and up to give the maximum amount of space to work on the fitting.
03-18-2018, 10:49 PM
  Fork Gaiters and Heated Grips tdbru 20 2,925 05-02-2025, 11:16 PM
  Spare connectors/Oxford heated grips White Dog_imp 13 1,437 04-18-2025, 10:02 AM
   HEATING GRIPS ICON HONDA ORIGINAL NON-OPERATING CB1100 ex 2015 EUROPE. COMPLAINT TO Alfgaxatico_imp 16 1,800 12-10-2020, 07:35 AM
Last Post: Alfgaxatico_imp
  HEATED GRIP HONDA ORIGINAL - CB1100 ex 2015 Alfgaxatico_imp 9 739 11-21-2020, 09:45 AM
  hand guards and heated grips misterprofessionality 33 2,270 11-16-2020, 10:06 AM
Last Post: mrded_imp
  thicker grips active1951_imp 15 1,163 08-04-2020, 12:55 PM
Last Post: gmike_imp
  Making closed end grips work on the CB Skypilot_imp 6 607 05-18-2019, 10:40 AM
  OEM ONLY HEATED GRIPS peterbaron 4 544 10-09-2018, 10:59 AM
   Good grips for CB1100? Which ones are you all installing? rdtshaw_imp 61 4,024 08-06-2018, 11:47 PM
Last Post: itstuantran_imp
  Threw on Rizoma grips and bar ends. silascopathic_imp 9 760 06-01-2018, 02:23 AM
Last Post: Mandrau_imp
