Where to tap speed sensor signal?
PowerDubs_imp Offline
Threads: 125
RE: Where to tap speed sensor signal?
Following this thread with interest as I've been wanting to use the speed input option on my power commander autotune box as well.
I've emailed a couple people but have not received conclusive responses so I haven't done anything.
I am more a mechanical guy, not electric. Smile
07-04-2018, 11:20 PM
SportsterDoc Offline
New Mexico
Threads: 33
Likes Received: 43 in 22 posts
Likes Given: 6
Max
Your post 9 appears to be a precautionary suggestion, not something necessary for the Signal Dynamics module to function, is that correct?
Received your email, last night. Will send you the schematic with the pink/green ending in the middle of the two pages. I am not seeing a VSP on that schematic.
On the ABS schematic, the front and rear VSP + and - on the brake module have no voltage indication, although the unit is powered by ignition voltage.
Thank you for all your input.
07-05-2018, 01:25 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Received: 211 in 121 posts
Likes Given: 155
Doc, which schematic are you looking at? The ‘14 ABS model?
07-05-2018, 01:34 AM
New Mexico
Threads: 33
Likes Given: 6
(07-05-2018, 01:34 AM)Lord Popgun_imp Wrote: Doc, which schematic are you looking at? The ‘14 ABS model?
In post 12, yes.
I will email you the other schematic that I just emailed Max.
07-05-2018, 01:42 AM
Lord Popgun Offline
Virginia
Likes Given: 155
OK, here is the problem. The one schematic is for the 2013 ABS.
The schematic that has page numbers ( 20-4 and 20-5) is incorrectly put together out of the ‘14ABS on the left, and the 2014 non ABS on the right. That is why it doesn’t look right. Because it isn’t.
Is your bike a 2014 ABS?
07-05-2018, 01:54 AM
New Mexico
Threads: 33
Likes Given: 6
(07-05-2018, 01:54 AM)Lord Popgun_imp Wrote: OK, here is the problem. The one schematic is for the 2013 ABS.
Thanks, Popgun, as that was very strange.
Both egleaves and mine are 2014 standards, which are non-ABS.
The speed sensor is at the rear brake, so I would expect that is where the pink/green should go.
Heading for the mountains, will check back this afternoon.
07-05-2018, 02:04 AM
peterbaron Offline
Likes Received: 620 in 338 posts
Likes Given: 1,057
Do you need me to look at my manual when I'll get home... so is for 2014 CB ABS ???
07-05-2018, 02:10 AM
Lord Popgun Offline
Virginia
Likes Given: 155
Max made the combined schematics from scans I made. My scanner takes 2 scans for each diagram as they are too long for my printer. I’ll send them to you, but you will have to print them out and put them together.
Or, Max can correct the error. I’m sure everyone knows, if your bike does not have ABS, there is no ABS modulator and the wiring and signal distrubution is not the same.
07-05-2018, 02:21 AM
egleaves_imp Offline
Threads: 11
I would love to get a hold of a wiring diagram for a 2014 CB1100E. The one I have says it for a CB1100A which, if I'm not mistaken, is the deluxe with ABS.
07-05-2018, 02:48 AM
peterbaron Offline
Likes Given: 1,057
(07-05-2018, 02:48 AM)egleaves_imp Wrote: I would love to get a hold of a wiring diagram for a 2014 CB1100E. The one I have says it for a CB1100A which, if I'm not mistaken, is the deluxe with ABS.
NO MAYBE MAKE SURE WHAT IT IS
07-05-2018, 02:51 AM
  wheel swap cad cnc lazer reluctor for speed sensor 1973cb750 13 3,559 10-28-2025, 05:56 AM
Last Post: 1973cb750
  Turn Signal Indicators balkanhound_imp 5 787 04-17-2025, 11:17 PM
  2014 CB1100 Clear Turn Signal Lenses Ngavrielidis1_imp 16 1,822 04-15-2025, 06:23 AM
Last Post: Ngavrielidis1_imp
  Negotiator-S Speed Pulse Modulator? TonyJames_imp 18 2,169 11-14-2022, 04:50 PM
Last Post: rich_imp
  Can someone with a power commander on a 6-speed bike check something for me? PowerDubs_imp 10 1,003 05-15-2022, 11:42 AM
  auto tune 02 sensor outback_imp 18 1,631 03-16-2022, 07:48 AM
Last Post: outback_imp
  Smaller turn signal/running light choices TxRonHarris_imp 33 3,060 07-06-2021, 10:00 PM
  Extra turn signal on dash Mixagon_imp 7 847 06-24-2021, 07:20 AM
Last Post: 17-CB-002
  Turn Signal Relocation Cormanus 11 1,088 12-30-2020, 11:12 AM
  Signal Relocation Ben70_imp 7 865 02-20-2020, 10:22 AM
Last Post: Ben70_imp
