How to lower your CB1100
LoneWoof_imp Offline
Threads: 4
RE: How to lower your CB1100
(08-02-2016, 01:42 AM)riceburner_imp Wrote: Does the lowered back end make it more difficult to get the bike up on the centerstand? Just curious as it would seem to me to alter the angle and leverage of stepping on the stand a little bit? I can live with tippy toeing a little bit as is.5'8' 30 inch inseam.
I believe lowering will create center stand problems. I'm 5'6, 28-29inseam and can almost flat foot. Do you have an after market seat?
Personally, I would get thicker soled boots before I would lower a bike from stock. Just me.
08-03-2016, 01:57 AM
BayAreaRick_imp Offline
Threads: 4
I've had thicker-soled boots since the beginning of riding - at 5'7", 29" inseam. Works well most of the times.
08-03-2016, 04:13 AM
Frulk_imp Offline
Threads: 108
I lower the back end of my CB every time I sit on it Confused
08-03-2016, 10:22 AM
CB4ME_imp Offline
Threads: 183
Webike has a 15mm lowdown kit for the rear shocks:
http://japan.webike.net/products/22827068.html
To make it easier to raise the bike on the center stand, use a short but wide, wedged shape piece of wood and ride the rear tire up to raise it. Makes a huge difference.
08-06-2016, 07:26 AM
Carguy1959_imp Offline
Threads: 8
I put 1.5 in lower shocks on my CB. I have no problem putting it on the center stand. I am 5'9" and 170 pounds. I can still put mine on the stand with a pair of Vans on my feet. I did have to readjust my shifter up a bit to keep my toes from dragging while shifting on a curve. Other than that, it rides fine.
08-07-2016, 12:57 AM
PowerDubs_imp Offline
Threads: 125
Are any of you guys taking the geometry change into account and lowering the forks in the triple tree?
08-07-2016, 06:30 AM
CB4ME_imp Offline
Threads: 183
(08-07-2016, 06:30 AM)PowerDubs_imp Wrote: Are any of you guys taking the geometry change into account and lowering the forks in the triple tree?
I certainly did on my NC700X. Very easy to do.
08-07-2016, 08:21 AM
Threads: 125
I saw you over on that board when I was researching bars. Wink
08-07-2016, 08:23 AM
Threads: 8
Before my bike sat a-- up, now it sits almost level. I like the stance better....
08-07-2016, 12:00 PM
Garver_imp Offline
Threads: 3
So is this CB owner confirming that Bonneville shocks and I'm guessing any shock made for the Bonneville are a direct swap for the CB? If anyone can answer this it would be very helpful with finding more less expensive options than Ohlins or Nitrons for better performance, thanks.
08-25-2016, 12:07 AM
  Lower Footpegs CB4ME_imp 21 1,440 04-12-2023, 01:37 AM
  How to lower seat for short-legged "freeks" Crossfire_imp 25 1,670 01-30-2022, 06:45 PM
Last Post: jtopiso_imp
  Lower gearing? Anyone done it? Magnus_imp 10 718 04-19-2016, 10:18 AM
  Anybody gear lower for the drag-strip? jeffskar_imp 6 483 09-06-2015, 03:20 AM
  Sprockets Lower RPM 1953andrejrigoli_imp 4 393 03-17-2015, 08:37 PM
Last Post: CIP57_imp
  Lower Handlebars & Fork Boots DGShannon_imp 4 374 10-08-2014, 12:48 AM
Last Post: DGShannon_imp
