Motogear Titanium Header and TSR Air Funnel
Likes Given: 789
RE: Motogear Titanium Header and TSR Air Funnel
another q...can you hear intake noise with that set up?
12-15-2013, 01:01 AM
HondaJon_imp Offline
Threads: 53
Nope, no intake noise, but the exhaust note is a bit louder due to the lack of a CAT.
CB4ME,
I'm done with the powertrain after the dynotune. The only other mod I may do is change the rear shocks. I'll wait for you to report on the ones you just installed before I move forward.
That air funnel REALLY makes a difference..Much more than I thought it would. The stock PC V maps seems to be working fine, but the dynotune is indeed in order
And, if I can get my hands on one, Install a Mugen chain guard....
12-15-2013, 02:03 AM
Threads: 53
Here is the Motogear header instructions. Note the silver vaccum valve on the airbox lid and all those hoses on pic #3. Glad we didn't get that piece of additional emissions equipment.
12-17-2013, 07:14 PM
Threads: 53
Having her dyno'ed today at 0900. Will post the results. Hoping for at least 95 HP...We'll see..
12-20-2013, 10:34 PM
CB4ME_imp Offline
Threads: 183
(12-20-2013, 10:34 PM)HondaJon_imp Wrote: Having her dyno'ed today at 0900. Will post the results. Hoping for at least 95 HP...We'll see..
Eagerly awaiting results!
12-20-2013, 11:19 PM
Threads: 53
96 HP first pull with stock PC V map
12-21-2013, 02:00 AM
lola_imp Offline
Threads: 18
(12-21-2013, 02:00 AM)HondaJon_imp Wrote: 96 HP first pull with stock PC V map
holy shiet! awesome numbers sir!
12-21-2013, 02:37 AM
CB4ME_imp Offline
Threads: 183
Wow! If a stock bike dyno's at around 80 hp, that's a 20% hp gain! Excited Banana Beer
12-21-2013, 04:11 AM
Threads: 53
Ok, guys, my shop was having printer issues and was told the map will be e-mailed to me. They were pretty busy today and as of this writing I have not yet received it. I know, no pics = it never happened. The map will be posted once I get it. Here is how it went.
The stock PC V map was pretty close, but it is a little lean up top.
The speed sensor seems to be an issue because it limits the bike to around 6K in 3rd gear, If you unplug it, the ECU knows somehow and it causes errors and doesn't allow for a complete tune. My shop is going to call Dynojet Monday and ask if they have any updates/fixes.
Bazzaz makes a fuel control similar to the PC V that has a "Speed Amplifier" that supposedly overcomes the sensor somehow. http://www.bazzaz.net/instructions/F391i.pdf I had never heard of them, but my shop told me the company was founded by an ex-Dynojet engineer and puts out good products. Maybe Deanohh can figure out what this "Speed Amplifier" does...
I am happy with the results and she runs super smooth. 97 HP was the final number and the power delivery is much more linear and instantaneous.
What I learned:
Titanium will turn colors just like stainless, so skip the polish option
CAT free is the only way to go if you really want to see what she can do
A speed sensor solution is needed to tune the bike to its full potential
The TSR air funnel makes a BIG difference
NO popping at all on decel, plug that PAIR valve
12-21-2013, 01:29 PM
Deanohh_imp Offline
Threads: 5
Bazzaz install is not exactly pnp. Bazzaz info says the amplifier is used to determine what gear the bike is in. It taps the speed sensor wire and I don't see how it could affect the speed limiter because the ecu doesn't get its speed signal directly from the sensor but from the Speedo head or if. Abs, from the abs brain. If the Speedo reads 112, the ecu sees 112, unless I'm wrong.
12-21-2013, 02:09 PM
  Stock exhaust or aftermarket header? milkmaster_imp 17 1,412 07-20-2023, 04:11 AM
  Air Intake Funnel? Jeeves_imp 9 808 07-17-2021, 02:46 AM
Last Post: Jeeves_imp
  Header coating Brady Bourgeois_imp 6 575 07-30-2020, 08:55 AM
Last Post: Retsel_imp
  Left over part from TSR Intake and Funnel install?? teamvisegrip_imp 5 522 09-21-2019, 10:48 AM
Last Post: teamvisegrip_imp
  TSR Air Funnel Kit kDiqq_imp 27 1,703 08-12-2019, 04:11 AM
Last Post: dUh!_imp
  Techserfu Titanium Exhaust misterprofessionality 19 1,623 09-16-2018, 05:35 PM
Last Post: 736cc_imp
  Moto gears header + BMS R-evo = good breathing itstuantran_imp 1 283 05-20-2018, 08:09 PM
  Over Racing full system titanium for CB1100RS Ban_imp 2 338 10-02-2017, 08:58 PM
Last Post: Ban_imp
  Yosh Titanium 736cc_imp 18 1,074 05-15-2017, 09:27 PM
  Header wrap installed Carguy1959_imp 18 1,282 10-18-2016, 07:43 AM
Last Post: ChipBeck_imp
