usb/cell phone charger setups.. ?
Olyrider Offline
PNW
Threads: 23
RE: usb/cell phone charger setups.. ?
This might be the next thing I put on my CB1100:
http://drzrider.com/store/MD7-universal-...p103497308
Low profile, with both a ram ball for my phone mount, and power for the charging cable.
And...here's a very cool USB plug to stick in it that also has a voltage display! Two birds with one stone...
[url=https://www.amazon.com/gp/product/B073WWQV6S/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1]https://www.amazon.com/gp/product/B073WW...UTF8&psc=1
04-10-2018, 02:39 PM
el duque_imp Offline
Threads: 23
hey Chandler,
received parts today.
Did you have to remove the tank to run the wire under it? Looks tight under there. I don't see how on first glance how to do it easily as in not removing the tank.
04-12-2018, 02:56 PM
chandler_imp Offline
Threads: 11
(04-12-2018, 02:56 PM)el duque_imp Wrote: hey Chandler,
I didn’t remove the tank. I just loosened the bolt and lifted it to get the cord passed. I used a long rod and taped the cord to it. Then, I just slid it back from the handle bars toward the tank. When I got close enough, I just loosened the tank and fished it out.
2013 Honda CB1100
04-13-2018, 02:55 AM
Threads: 23
thanks.
I was thinking how I could do it without the tank being removed.
that did cross my mind, but I like to double ck.
onward.
04-13-2018, 08:50 AM
emullick_imp Offline
Threads: 2
(04-09-2018, 10:45 AM)Lord Popgun_imp Wrote: You have any number of options depending on what kind of connector you want. There is an accessory connector in the headlight shell you can use for switched power (there is also one in the battery area). Or you can wire directly to the battery.
You can get Powerlet outlets or a 2 wire SAE connector like chargers use, or a cigarette type outlet. And then a USB or whatever adapter.
As an example on my ST1300 I have a Powerlet outlet and adapters for a few different things. On my CB I have a 2 wire SAE connector plugged into the headlight shell accessory connector and adapters for that too. The example posted above would work on my CB.
Be aware that unless you buy the connector, pins, and a crimping tool you will either have to tap the wires or dike the connector and splice onto the wires of the accessory connector.
I am installing a cell phone and want to power it from the headlight accessory connector. What connector is the least trouble to use, you mention a "2 wire SAE". What is that and where can I get one?
04-17-2019, 10:56 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
You can buy them at any auto parts store, or I think Home Depot or Lowes and Walmart. Here is an amazon link that shows what they look like: [url=https://www.amazon.com/WGCD-Power-Automotive-Extension-Cable/dp/B06VWS2S3Y/ref=sr_1_9?crid=2OJDV07HOU1PM&keywords=sae+connector&qid=1555550312&s=gateway&sprefix=Sae+conne%2Caps%2C184&sr=8-9]https://www.amazon.com/WGCD-Power-Automo...184&sr=8-9
If you type SAE connector in the amazon search box a wide variety of them show up, not just the connector with unterminated wires.
Green is ground on our bikes so you will connect green to the black SAE wire and the other wire to the Red wire. Once you have the connector installed you can buy a number of accessories or adapters that will plug into it. Right now I have a voltage monitor plugged into mine. This one: [url=https://www.amazon.com/Battery-Tender-081-0157-Disconnect-Voltage/dp/B00DJ5KE9A/ref=sr_1_3?crid=PVIVLE5PPF03&keywords=sae+voltage+meter&qid=1555550695&s=gateway&sprefix=sae+voltage%2Caps%2C146&sr=8-3]https://www.amazon.com/Battery-Tender-08...146&sr=8-3
Or here is a USB adapter: [url=https://www.amazon.com/Battery-Tender-081-0158-Disconnect-Smartphone/dp/B00DJ5KEF4/ref=sr_1_17?crid=332DTBAIN0Q6Y&keywords=battery+tender+cable&qid=1555550766&s=gateway&sprefix=Battery+tender%2Caps%2C232&sr=8-17]https://www.amazon.com/Battery-Tender-08...32&sr=8-17
Powerlet connectors and accessories are really nice, but cost more and aren’t as available. Easy to get online. Wiring is easy as it’s still only 2 wires. I have it on my ST1300 as the original owner installed Helibar risers with the Powerlet and Ram ball option. So I have various adapters for that. Otherwise I would have installed an SAE connector and called it a day Smile
Disclaimer: Although Green is ground on our bikes, there is always the possibility of a factory wiring error. Some 2014 models are wired wrong in the tail light circuit, for example. ALWAYS check the wiring with a meter to insure proper wiring.
04-17-2019, 11:27 AM
Threads: 2
(04-17-2019, 11:27 AM)Lord Popgun_imp Wrote: You can buy them at any auto parts store, or I think Home Depot or Lowes and Walmart. Here is an amazon link that shows what they look like: [url=https://www.amazon.com/WGCD-Power-Automotive-Extension-Cable/dp/B06VWS2S3Y/ref=sr_1_9?crid=2OJDV07HOU1PM&keywords=sae+connector&qid=1555550312&s=gateway&sprefix=Sae+conne%2Caps%2C184&sr=8-9]https://www.amazon.com/WGCD-Power-Automo...184&sr=8-9
I decided to solder the cell phone mount/charger wires directly to the auxiliary wires in the headlamp, not much room in there for connectors. Discarded the original female connector. Green is ground, black is positive.
04-22-2019, 12:34 PM
Lord Popgun Offline
Virginia
Likes Given: 142
Thumbs Up
04-22-2019, 07:27 PM
  Phone or Sat Nav? What mount ? Quad lock or...... Davidjill_imp 18 1,408 07-28-2024, 08:49 AM
Last Post: SportsterDoc
  Installation of a Quad Lock Wireless Charger [No Cut Mod] LayerCake_imp 5 665 06-17-2022, 07:44 AM
Last Post: LayerCake_imp
  Phone mounting issues ride4now_imp 37 2,728 09-29-2021, 05:42 AM
  Deltran USB Charger use2b_imp 8 543 08-20-2018, 11:52 AM
  My phone as GPS didn't pan out el duque_imp 21 1,288 05-07-2018, 01:54 PM
Last Post: Offroad
  Phone mount pittycheria_imp 5 398 06-11-2017, 07:00 AM
Last Post: jdvalero_imp
  Ram X grip for cell phones and GPS uscgmac_imp 31 1,697 02-26-2016, 01:09 PM
Last Post: uscgmac_imp
  Battery Charger - Inexpensive rbike_imp 0 219 12-20-2015, 10:19 PM
Last Post: rbike_imp
  Phone mount for iPhone 6+ Cras_imp 18 1,133 10-28-2014, 11:47 PM
Last Post: DGShannon_imp
  Cell phone mount Ridem32_imp 25 1,638 05-05-2014, 01:46 PM
Last Post: Ridem32_imp
