Sourcing Black Fork Tubes
LongRanger_imp Offline
Threads: 129
RE: Sourcing Black Fork Tubes
You may want to try Frank's Machining and Engineering. They specialize in replacement fork tubes and may be able to provide assistance. http://www.franksforks.com
08-12-2019, 04:46 AM
cb1100_dude_imp Offline
Threads: 10
Thank you all for the ideas! I'll give it some thought and update this thread if there's a viable option forward
08-12-2019, 05:29 AM
Likes Received: 629 in 282 posts
Likes Given: 795
(08-12-2019, 04:19 AM)pekingduck_imp Wrote: You could use a plastic sleeve cut to length. If it is too large in diameter, slit it and zip tie at top and bottom. I have used the 1.5" polyethylene tubes golfers use in their golf bags to separate the clubs on older 35mm forks.
They make them in 2" OD diameter that will easily fit over our 41mm forks. They are cheap, about $5, and you can slide them off if you need to work on the forks.
See, that's what I was talking about. Good idea PD!
(08-12-2019, 03:49 AM)EmptySea_imp Wrote: Gotcha. I have done neither, but I'm only at 24,000 on this bike. Plus I am so slow through the turns that the forks never compress much anyway.
ROFL
08-12-2019, 06:32 AM
(08-12-2019, 03:05 AM)The ferret_imp Wrote: wouldn't vinyl wrap make it nearly impossible to slide the tubes out of the trees?
I reckon the owner would just slit open the wrap, dispose of it, and put a new wrapper on after the fork job is done, or maybe before the fork job is done. Dodgy
08-12-2019, 09:02 AM
Likes Given: 795
Im not familiar with wrap, apparently it isnt too sticky then?
08-12-2019, 09:47 AM
(08-12-2019, 09:47 AM)The ferret_imp Wrote: Im not familiar with wrap, apparently it isnt too sticky then?
Actually, I don't know. I am making an assumption it is some sort of heat shrink wrap, or possibly some low tack substrate.
Arguably, one could pay the owner to advertise their wears on the forks wrap (e.g. Monster Drink, Coca-Cola, Popeye's, Trojan, etc.) Smile
08-12-2019, 09:58 AM
  Bending tubes The Gecko_imp 1 284 09-18-2023, 05:16 AM
  Need help sourcing racks for Aluminum Panniers Frulk_imp 15 1,067 03-06-2019, 08:22 AM
  ID these fork boots/ fork gaiters Riko_imp 9 867 12-18-2017, 09:43 AM
Last Post: LongRanger_imp
   Photoshop wizzkids request -> black out fork, peg bracket, shock spring Riko_imp 16 1,341 03-05-2016, 09:51 AM
Last Post: Chapomis_imp
  Honda CBR F4 fork tubes dailyrider_imp 0 168 07-20-2013, 04:58 AM
Last Post: dailyrider_imp
