Sourcing Black Fork Tubes
cb1100_dude_imp Offline
Threads: 10
Howdy All! Biker
I want a badazz murdered out CB cafe...
- anyone have any experience with blacking out their fork tubes or purchasing fork tube replacements?
- Is it as simple as buying same length and width but in a different but coated version?
Here's my previous cafe set-up that I might bring my bike back to. I keep changing my bike on theme Tongue I have probably painted my tank around 7 times now.
08-11-2019, 12:01 PM
Retsel_imp Offline
Threads: 24
All that an no RLETS? I don't know if "badazz" is achievable without? Nice looking ride though.
08-11-2019, 12:26 PM
RE: Sourcing Black Fork Tubes
Blacked out header pipes look good.
08-11-2019, 01:03 PM
Likes Received: 616 in 276 posts
Likes Given: 788
I would think you could get some tubing, plastic or metal, cut to length to fit between the trees and paint them black, then simply slide them over the upper fork tubes.
08-11-2019, 01:24 PM
Desert viper_imp Offline
Threads: 7
I’m vinyl wrapping my R1200R gold forks black.....do a google search for videos
08-11-2019, 04:09 PM
Likes Given: 788
wouldn't vinyl wrap make it nearly impossible to slide the tubes out of the trees?
08-12-2019, 03:05 AM
Likes Given: 91
(08-12-2019, 03:05 AM)The ferret_imp Wrote: wouldn't vinyl wrap make it nearly impossible to slide the tubes out of the trees?
Great question, but my follow up might be: how often does one have to slide the tubes out of the trees?
08-12-2019, 03:17 AM
Likes Given: 788
if you get a leaking fork seal, or want/need to change the fork oil (there is a spec for that that nobody follows). For some that means never, for others, well, we have already had several on the board with leaking fork seals and several that have changed fork oil.
08-12-2019, 03:33 AM
Likes Given: 91
Gotcha. I have done neither, but I'm only at 24,000 on this bike. Plus I am so slow through the turns that the forks never compress much anyway.
08-12-2019, 03:49 AM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
You could use a plastic sleeve cut to length. If it is too large in diameter, slit it and zip tie at top and bottom. I have used the 1.5" polyethylene tubes golfers use in their golf bags to separate the clubs on older 35mm forks.
They make them in 2" OD diameter that will easily fit over our 41mm forks. They are cheap, about $5, and you can slide them off if you need to work on the forks.
08-12-2019, 04:19 AM
  Bending tubes The Gecko_imp 1 272 09-18-2023, 05:16 AM
  Need help sourcing racks for Aluminum Panniers Frulk_imp 15 1,016 03-06-2019, 08:22 AM
  ID these fork boots/ fork gaiters Riko_imp 9 821 12-18-2017, 09:43 AM
Last Post: LongRanger_imp
   Photoshop wizzkids request -> black out fork, peg bracket, shock spring Riko_imp 16 1,235 03-05-2016, 09:51 AM
Last Post: Chapomis_imp
  Honda CBR F4 fork tubes dailyrider_imp 0 158 07-20-2013, 04:58 AM
Last Post: dailyrider_imp
