Side Covers
YotaMan_imp Offline
Threads: 1
RE: Side Covers
Humm... everyone has me thinking here now. Though I love the side covers on the '14 DLX model the best, I'd probably want to see the mounts on the backside before I pull the trigger on those and repaint. I'd love to make these work though.
I don't mind the side covers Richard mentioned, I just prefer the style of the DLX just a little more. It would probably be a good option - if the paint matches. I would need to find out if the paint colors are the same though. I don't even know what my 2017 EX paint color is. I should have looked to see if it was on the title before I gave it to the state for my tax and registration. When I get the new one back it will probably just be listed as "red."
The process redbirds mentions here isn't a bad idea either. Though not sure how that would turn out on aluminum since it's a little 'rough' - noticed yours were plastic on your '13. I'd probably just order some plastic '13 model ones and repaint like you did if I go that route.
OR
I did find this on Samurider, but again, not sure on the paint color. https://www.samurider.com/?p=26886/#itemImage
02-14-2020, 12:33 AM
Houtman_imp Offline
Threads: 115
RE: Side Covers
All years have different mounting tabs in the back . I just went opposite what you did and had 2017 side covers made in Japan to fit my 2014. It worked out ok but not perfect. I much prefer the 2017 alu covers over the two tone 2014 .
02-14-2020, 12:46 AM
YotaMan_imp Offline
Threads: 1
RE: Side Covers
Crazy that the tabs were different every year!!! I might have to order an extra set of side covers if these samurider ones are different. I don't want to mess up the stock ones as I'd like to keep the originals with the bike too. I think I found the paint name though.
[Image: b1cbacfc762338d52125e73ad0f5dde2.jpg]
02-14-2020, 01:00 AM
alprider Offline
Threads: 92
RE: Side Covers
btw.
start by 17 models: its nomore plastic, its a (brushed) aluminum cover
02-14-2020, 01:08 AM
YotaMan_imp Offline
Threads: 1
RE: Side Covers
(02-14-2020, 01:08 AM)alprider_imp Wrote: btw.
Yep they are aluminum. I just prefer the painted look. Inquiring at Samurider for painted ones.
[Image: f65be174cadfbdb94341a372a879e778.jpg]
02-14-2020, 01:13 AM
alprider Offline
Threads: 92
RE: Side Covers
ok the 19 models are paintet aluminum...btw. the fenders are still metal but too paintet
02-14-2020, 01:15 AM
redbirds_imp Offline
Threads: 186
RE: Side Covers
I'd simply paint the aluminum covers. At the Colorrite site you put in year and model of your bike and they have the proper paint match for it, no guesswork.
02-14-2020, 05:00 AM
Likes Given: 1,016
RE: Side Covers
YotaMan, the paint code should be on a tag under the seat.
02-14-2020, 06:21 AM
YotaMan_imp Offline
Threads: 1
RE: Side Covers
(02-14-2020, 06:21 AM)Cormanus_imp Wrote: YotaMan, the paint code should be on a tag under the seat.
Thanks on the under the seat info. I'll check it out!
I did go to the ColorRite website and the 2017 isn't listed.
02-15-2020, 04:05 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
RE: Side Covers
The code will be on a sticker on left side on a frame rail under the seat, like Cormanus said. Should start with R. Then look up the color for that code and see if it comes up. If you can’t find it let us know and we/I can post a pic.
02-15-2020, 04:10 AM
  2017 CB1100EX Color matched side covers ceeko_imp 66 4,338 06-25-2023, 10:17 PM
  side covers plastic or aluminium? mrded_imp 8 732 10-03-2020, 11:33 AM
  Aftermarket Brake and Clutch Reservoir Covers michael1954 11 975 06-17-2020, 08:42 AM
Last Post: Mtneers
  Aluminium side covers for 2014 Houtman_imp 8 624 08-15-2019, 02:00 PM
Last Post: Desert viper_imp
  Installed red side covers on 2013 CB1100 Frulk_imp 15 1,256 10-05-2018, 02:54 PM
  Advice for removing emblems on side covers misterprofessionality 26 2,092 05-01-2018, 07:28 AM
  Dremeled my side covers- what do you think? PowerDubs_imp 71 4,065 02-22-2018, 03:19 AM
  Force Design air cleaner covers and side covers Bheezy27403_imp 12 945 02-19-2018, 01:44 AM
Last Post: Bheezy27403_imp
  Need help with part number for side covers jedd_imp 2 336 11-27-2017, 10:08 AM
Last Post: jedd_imp
  Any nice master cylinder covers out there? greekcb_imp 0 226 11-04-2017, 09:02 AM
Last Post: greekcb_imp
