Hagon Shocks: Response to Inquiry
LikeAfox_imp Offline
Threads: 3
RE: Hagon Shocks: Response to Inquiry
(12-13-2021, 01:47 PM)michael1954_imp Wrote:
(12-12-2021, 10:42 AM)LikeAfox_imp Wrote: Would you happen to have a link?
Edit: Nevermind, found them easily https://www.ebay.com/itm/143736471858?ha...SwphhfX0Iq
But I fail to see how they are different (or even better) than OEM shock absorbers.
Never have used them, but are they really that bad? I placed Progressive shocks on the 2003 Speedmaster I have shown here on the Forum back when I had it, and they totally outclassed the Triumph shocks that were stiff and slow to rebound.
Put a pair on the 82' GS1100 I am also working on right now because the stock OEM were rusted ugly. Have yet to ride it at speed, but when done, I will chime in. After the DLX is finished of course
Nobody said they are bad, but manufacturer didn't explain how exactly they are better than OEM. I'm sure you're aware of many cheap garbage replacement parts from no-name brand littering online marketplaces. Those are often build from inferior materials with wild discrepancies in specifications.
For example, you can buy a copy of SWMotech guards on ebay for %60 less, directly from China. Except they are made from potmetal tubing with a quick coat of primer. And will not protect your engine in case of significant impact.
But on the other side of things, reputable brands like Ohlins will give you a dyno printout of the shock absorber you're buying. Progressive Suspension has a shock and spring rating for every item they sell. You can pick and choose your stiffness/rebound/load rate at the checkout.
Now click on that Ebay link and see what Hagon is promising. "Completely equivalent to standard shock absorbers", "perfectly interchangeable with the original ones", "valid alternative to the standard ones" etc. They only claim to be OEM-equivalent, which is more than direct-from-china trash, but not enough to think of them as an upgrade. Unless you really like the look or something. Or your original shocks went bad all of a sudden and you need a cheaper replacement.
12-20-2021, 06:32 AM
  Windshields: Two Reviews and an Inquiry JRD 9 658 01-31-2026, 02:50 PM
  Road Comet Masqeroad: A Beautiful Pragmatic Response rdprdp01 7 1,048 05-04-2025, 11:33 AM
Last Post: rdprdp01
  Road Comet: A Beautiful Pragmatic Response rdprdp01 12 1,058 10-29-2024, 12:25 AM
Last Post: rdprdp01
  Hagon Rear Shock Review dUh!_imp 2 463 09-18-2022, 10:55 PM
Last Post: KiowaEagle_imp
  Nitro Piggy Back Shocks touchetteweb_imp 3 385 03-29-2022, 12:39 AM
  New YSS shocks,Hyperpro Progressive front springs,gators ozigoo 10 976 10-03-2021, 04:03 AM
  ZRX Shocks( Probably Revisited) Rox_imp 3 392 10-30-2020, 12:16 PM
Last Post: IndianRider_imp
  Amazon rear shocks DBM_imp 11 844 03-10-2019, 01:26 PM
Last Post: qmaven_imp
  Ohlins shocks for 2017 Houtman_imp 27 1,759 11-29-2018, 02:50 AM
Last Post: nhawk7504_imp
  Ohlin Shocks for 2017 Houtman_imp 4 431 09-02-2018, 03:02 AM
