Accessory Removal
Nachodaddy Offline
Litchfield Park, Arizona, USA
Threads: 10
Likes Given: 483
RE: Accessory Removal
(03-16-2022, 11:48 AM)The ferret_imp Wrote: I was going to mention he could also use it for a heated jacket liner when I remembered he was from Az. Doh!
The climate in Arizona ranges from hot to cold. We have ski slopes and sand dunes. The northern part of the state and those with higher elevations are often fairly cold. It just depends on where you are and where you plan to ride.
03-16-2022, 11:54 AM
(03-16-2022, 11:53 AM)The ferret_imp Wrote: ROFL was 113 during the day the last time I was there motorcycling, but it did frost up at night the last time I was in Az Javie hunting in the desert.
Ja. The desert can be an extremely unforgiving place no matter the light level.
Wagonpeddler_imp Offline
Threads: 15
Believe it's directly attached to the battery as there were 2 extra leads when I attached my own battery tender....should have left them there. Didn't think of that one.
03-16-2022, 07:35 PM
Threads: 15
Got it out...all except a few inches under the tank that I couldn't reach. Whoever installed it spared no expense in cable ties! Now I can easily get the key in & out, and see the right turn signal indicator.
03-22-2022, 05:22 AM
  2017 OEM CB1100EX/RS Accessory Brochure rdprdp01 0 335 04-16-2025, 02:05 AM
Last Post: rdprdp01
  Crank Case Cover removal? JF Coastal_imp 47 3,330 08-04-2023, 01:26 PM
  Ignition switch live accessory wire? ozigoo 10 888 02-18-2021, 02:32 PM
Last Post: ozigoo
  Tank Removal... Bazbro_imp 17 1,282 03-08-2019, 05:42 PM
Last Post: Bazbro_imp
  Accessory connector inside headlight bucket 17-CB-002 4 439 10-29-2018, 02:36 AM
Last Post: 17-CB-002
  Choice of Fog /Accessory Lights Ennsync_imp 5 524 10-16-2018, 05:20 AM
Last Post: Ennsync_imp
  Home-made Accessory 3rdbike_imp 9 915 05-10-2018, 11:17 PM
  Accessory recommendation for a long ride chandler_imp 22 1,605 06-27-2017, 11:15 PM
Last Post: Rollie Bruner_imp
  New accessory parts on eBay - Just posted. pekingduck 4 499 03-19-2017, 03:08 PM
  Custom rear fender removal. Rebel73_imp 17 1,266 03-15-2017, 06:49 PM
Last Post: c-breezy_imp
