Whats it worth
Many thanks once again
Just from a safety point of view is there a method of locking the bike in position so you don't simply push it off the prop stand or is it a case of grabbing the front brake during manoeuvres?
Best wishes
Chris
[/quote]
The sidestand leg portion is adjustable fore-and-aft. So with the front wheel as far forward as it will go, you position the sidestand leg very close to the back side of the deployed sidestand. That way, when you roll in, put the sidestand down, then tilt it to the left, it is definitely locked in place. It can't shift around until the bike is set upright. It becomes very secure, more so than if it were on the garage floor.
[/quote]
I keep an eye on prices on Auto Trader. You can now get a new CB1100 EX or RS for around £9,000. I would have thought yours would be c£5,500, given its low mileage.
Obviously, it depends how much you want to sell it. You might have to be a bit lower to move it.
Beerman
Also been looking at the ones that fit under the centre stand but cant find any listed to fit the CB. Has anyone used one of these and f so what fits the CB please.
Best wishes
Chris
Many thanks
(08-25-2020, 07:31 AM)Beerman_imp Wrote: I keep an eye on prices on Auto Trader. You can now get a new CB1100 EX or RS for around £9,000. I would have thought yours would be c£5,500, given its low mileage.
Beerman
(08-25-2020, 06:27 AM)Chris Goldson_imp Wrote: Many thanks once again
Best wishes
Chris
[/quote]
[/quote] Just from a safety point of view is there a method of locking the bike in position so you don't simply push it off the prop stand or is it a case of grabbing the front brake during manoeuvres?
Best wishes
Chris
[/quote]
[/quote]
Chris, if you are looking at the picture of the bike on the WilTec stand, be advised that the bike there is photo-shopped in. Normally the front wheel goes all the way forward to the silver crossbar. The WilTec is much more adjustable than the US one, so you can slide the sidestand portion fore-aft before tightening it permanently.
By adjusting the sidestand portion as described, it really locks it in place. The bike can't go forward as the front tire is up against the forward stop. And because you've adjusted the side stand leg to be as far forward as possible, up against the back of the extended sidestand, it can't go backwards.
As an alternative, an appropriate-sized block of wood aft of the sidestand would also lock it in. I used to have my top-heavy 600 pound Moto Guzzi Breva 1200 Sport on it, and it had a slim, forged aluminum sidestand that I never trusted.
The second pic shows how a bike should fit. Because it is the American one, it doesn't have as much adjustability, and you can see where a little block of wood should go, for greater security. If your concern is that the front wheel will roll over the bar, it certainly won't by pushing it.
(08-25-2020, 03:07 AM)motoWest_imp Wrote:
(08-25-2020, 12:49 AM)pekingduck_imp Wrote: Chris, if your main reason to sell it is maneuvering in the garage or tight space, maybe consider one of the Harbor Freight motorcycle dollies. They are really well designed and sturdy. I've had one for more than 10 years. Just $80 (before the normal 20% off coupon).
Wow, I wish I knew this existed earlier. If I want my car and the CB in the garage, it takes me about ten minutes and a 9-point turn to fit the bike in there just right. It's the one time I really wish the bike were about ~100lbs lighter.
I am in a similar situation. I have 3 motorcycles, a truck, a car, and all my tools (2 roll-arounds, 2 work benches, and a radial arm saw) and a washer and dryer stuffed into my 2 car garage. I park my bikes on the center stand, and use brute force to slide them around every time I need to get one of them out, or the car or truck out. Takes me about 10 minutes to get a motorcycle out. One more thing - I use the bed of my pick-up for storage - unloading / loading it each time I drive the truck.
Everyone seems to have the same amount of garage space - not quite enough. I use a bunch of centerstand dollies to make the most of the space. In one end of the workshop, my Bonnie blocks my CB1100, which blocks my lathe. But I can get to the lathe in seconds sliding them sideways.
While I'd love a huge garage, I know I'd eventually come back to the same problem, but with a fleet of dollies.
If that quote doesn't exist on a t-shirt, it should.
As my wife and I sometimes ponder the possibility of owning a single story home down the road (the 1920's bungalow we now reside has two floors plus a basement), I dream of a larger, nicer garage. Fun to think about, not likely to happen any time soon.
Lol I have 3 motorcycles, a quad with snow plow, a work bench and a shelving unit in my half of our two car garage. My truck sits outside. Getting anything out of the garage means a lot of shuffling, but the two bikes I ride most are parked side by side right by the garage door for easy access.
About 7 years ago, we decided to build a house that more appropriately reflected our lifestyle. House square footage shrunk by 40%. Garage square footage tripled. Had 4 bikes at the time so you know, priorities.
Related, the concept of "expand to meet capacity" is real.
^That means^ good progress and moto planning = approvedThumbs Up
  Recent purchase, whats next? Classico_imp 8 667 03-28-2022, 03:36 AM
Last Post: apex1_imp
  Wow, this one is worth the high asking price postoak_imp 9 740 10-23-2017, 04:22 AM
Last Post: CB1100DLX_imp
  Service contracts are they worth it on a new 2017 cb pittycheria_imp 14 850 05-23-2017, 05:41 AM
Last Post: EarsOnWheels_imp
  Whats old is new again. Hiram E. Varona_imp 22 1,528 04-02-2016, 12:11 PM
Last Post: gmike_imp
  whats the diff between the cb1100 and the cb1100f nitro50@comcast.net_imp 26 2,076 06-03-2015, 04:49 AM
Last Post: SanPete_imp
  5sp Vs. 6sp. whats the difference when riding? disorientedpilot_imp 27 1,957 08-28-2014, 01:42 AM
Last Post: ClassicVW_imp
  AIMEXPO ,worth going to ? Houtman_imp 2 284 06-16-2014, 10:53 PM
  Is Synthetic really worth it? PJV_imp 50 3,363 09-23-2013, 03:38 PM
Last Post: GSAviator_imp
