Negotiator-S Speed Pulse Modulator?
PowerDubs_imp Offline
Threads: 125
(07-12-2022, 07:37 AM)1973cb750_imp Wrote:
(07-10-2022, 10:38 AM)tommymck_imp Wrote: Out of curiosity, under what circumstances are you guys running a CB1100 over 112mph? Not judging, just curious...
i want to do a standing mile event with mine but thatl never happen with the limiter
Nice. I’ve been to a few airport runway speed events - but never on a bike, just in my cars.
top of 3rd gear, going into 4th.. is usually the situation for me, running with my buddy on his z900. he likes to just go to 115, hold it there and do the slow walk away. lol.
BikerROFL
BikerROFL
Made me laugh.
07-12-2022, 01:25 PM
TonyJames_imp Offline
Threads: 1
RE: Negotiator-S Speed Pulse Modulator?
(07-09-2022, 10:17 AM)TonyJames_imp Wrote: I've been researching how to take my speed limiter off on my 2013 cb1100 and since guhls motors no longer does that i was wondering if anyone has used the special agent Negotiator-S Speed Pulse Modulator and if it works well and easy to install?
https://japan.webike.net/products/20034107.html
UPDATE: I pulled the trigger on it and after a little bit of translating and double checking the wiring diagram of the bike I was able to get it all wired up and it works great no issues and no more speed limiter
11-11-2022, 03:15 PM
rich_imp Offline
Threads: 15
could we just fill in every other slot in the trigger wheel
ECU may think we are going half fastROFL
11-11-2022, 04:27 PM
Interesting. What might a ground velocity of 180 km/h (112 mph) look like on the speed dial?
11-11-2022, 10:58 PM
Nachodaddy Offline
Litchfield Park, Arizona, USA
Threads: 10
Likes Received: 196 in 112 posts
Likes Given: 502
(11-11-2022, 04:27 PM)rich_imp Wrote: could we just fill in every other slot in the trigger wheel
I've done a few half-fast things in my life, but this is so crazy, it might just work.
In a half-fast way. . . Big Grin
11-12-2022, 02:45 AM
Threads: 1
(11-11-2022, 11:44 PM)m in sc_imp Wrote: this is good to know. I was eyeballing that all year. glad it actually works. any insight as to things to watch out for on install?
There where a few things that made it confusing but you can just translate the install guide from Japanese to what ever you can read, then the other obstacle was that in japan they seem to have a slightly different wiring harness and ecu so you will need the wiring diagram to figure out which wire you need to cut and connect to the module. other than that just need to make sure you do a good job on soldering the connections.
so with no speed limiter my stock bike will now go 140mph on the top of 4th but that's where the speedometer stops and it seems to slow down to 135 in 5th so there is some tuning that needs to be done to go any faster.
11-12-2022, 05:51 AM
Randy B Offline
Palm Bay, Florida USA
Threads: 85
Likes Given: 133
so with no speed limiter my stock bike will now go 140mph on the top of 4th but that's where the speedometer stops and it seems to slow down to 135 in 5th so there is some tuning that needs to be done to go any faster. That was my question....if the speedometer stays accurate. Good deal.
11-13-2022, 02:43 AM
I reckon with some spare time, one could take a Raspberry Pi Zero and a wee bit of interfacing hardware and leverage the Honda sensors and design up a reliable and accurate (and re-configurable) speedo computer. Can probably do it with a much less embedded system. The Zero W already comes with WiFi built-in, which is useful.
11-13-2022, 07:05 AM
rich_imp Offline
Threads: 15
let us know what you do in the 1/4
11-14-2022, 04:50 PM
  wheel swap cad cnc lazer reluctor for speed sensor 1973cb750 13 3,322 10-28-2025, 05:56 AM
Last Post: 1973cb750
  Can someone with a power commander on a 6-speed bike check something for me? PowerDubs_imp 10 927 05-15-2022, 11:42 AM
  Headlight Modulator On a 2017 EX? Paris_imp 2 426 10-23-2018, 05:59 AM
Last Post: Paris_imp
  Where to tap speed sensor signal? egleaves_imp 93 6,059 10-19-2018, 08:49 AM
  Magnum Speed/Rev Limiter Box? bflint 4 562 06-07-2017, 03:32 AM
Last Post: bflint
  5 speed to 6 speed conversion? Shinchan_imp 7 673 07-17-2016, 11:06 PM
Last Post: Shinchan_imp
  2013 6 Speed Upgrade - AKA 2014 DLX Sprocket Cover the_undecider_imp 7 710 01-28-2015, 03:04 AM
Last Post: Papa Weeley_imp
  Brake light modulator/flasher in a bulb dBuster_imp 7 721 06-24-2014, 03:20 AM
Last Post: Ridem32_imp
  2013 6 speed 1100rider_imp 12 810 05-02-2014, 10:19 AM
Last Post: Tortuga_imp
  Review of Comagination Headlight Modulator (to increase rider visibility) rjk555_imp 2 317 11-28-2013, 08:06 AM
Last Post: rjk555_imp
