What cruise control are you using for your CB1100?
Razor Offline
Threads: 32
Likes Received: 58 in 13 posts
Likes Given: 15
RE: What cruise control are you using for your CB1100?
Thought I'd throw this in just in case someone might want another option.
How about a true cruise control?
Back in 2006 I installed an Audiovox #CCS-100 on a ST1300. The trickiest part was concealing the control module (vacuum operated).
Fast forward... Rostra makes a universal kit. Not sure where you'd place the control module (electronic), but might make for an interesting project.
http://www.rostra.com/universal-aftermar...rostra.php
09-07-2015, 11:01 AM
White Dog_imp Offline
Threads: 59
(09-07-2015, 10:21 AM)Lord Popgun_imp Wrote: Their web site does list the CB1100 and shows this model MCUVOO UNIVERSAL VISTA - 7/8"
for both '13 and '14.
http://www.soundoffrec.com/fitcharts.aspx select your bike on that page
That's the model I have on my '14. Slight modification needed but I have the KURY grips. Mine does not hold the speed all that great but it holds long enough for me to shake my hand due to the numbness I get from carpel tunnel.
09-07-2015, 11:44 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
(09-07-2015, 11:01 AM)Razor_imp Wrote: Thought I'd throw this in just in case someone might want another option.
And they work great from what I read. But they are car or modified car CCs and that worried me some. I think there is only one dedicated motorcycle cruise control. Made in Australia and is expensive. http://www.mccruise.com/#
Of course, our bike is not listed.
09-07-2015, 12:02 PM
flynrider Offline
Phoenix, AZ
Threads: 28
Likes Received: 6 in 2 posts
OK, that's the same model I have on the CB750. I tried it on the CB11, but since the throttle cables come out of the forward part of the pod instead of the bottom (like the CB750), I found the thumb switch ended up much too low to easily reach with my thumb.
09-07-2015, 02:53 PM
Andor_imp Offline
Threads: 0
(08-31-2015, 01:29 PM)goldeneye_imp Wrote: Hey guys, I would like a cruise control similar to Throttle Meister, but I have been unable to find anything like it. Does one of the other Throttle Meister models work for the CB1100 or what cruise control mechanism are you guys using for you CB1100?
I have this
http://www.ebay.it/itm/HIGH-QUALITY-Omni...5d402c99af
I have this
Use this model is robust aluminum alloy, can be mounted on all bikes, it is important that the throttle does not slip ..... otherwise the speed goes down ...... just lift the throttle and put glue ..... there are other models on ebay but this beats them all ..... nothing .... electrical things or plastic has a high cost but it is worth it ...... finished tingling in the hand .... sorry my translation ..
09-07-2015, 09:31 PM
GaryMNM_imp Offline
Threads: 2
Yup, the 7/8 is what I just installed. I didn't get it set up like I prefer but it's workable using your thumb and /or index finger to activate. It easily pops off with a thumb or knuckle from your index finger.
Here's how it turned out on the CB:
Installed on CB1100
Here's my preferred install position as shown on my Valkyrie, much less obtrusive. I did try this method but it was binding too much for my comfort. Using this install location it merely takes a simple reach-a-round to activate/deactivate. Also shown in this pick is the Kuryakyn Universal Throttle Boss.
[url=https://goo.gl/photos/dkuWLuSqtNXwZhp1A]Hidden Vista Cruise Installed On The Valk
[url=http://www.soundoffrec.com/fitcharts.aspx]http://www.soundoffrec.com/fitcharts.aspx select your bike on that page
09-08-2015, 06:29 AM
Nemo_imp Offline
Threads: 55
Go Cruise Aluminum. Excellent gadget.
10-22-2015, 12:01 PM
Wisedrum Offline
Threads: 9
Likes Given: 3
No electronics, I also use this one, a hand cruise control.
Wisedrum
10-23-2015, 03:49 AM
Seabee_imp Offline
Threads: 2
(09-06-2015, 01:09 PM)specialist8_imp Wrote: More of a throttle assist, but it's the cheapest alternative to any cruise control device as it really helps dampen cramping. Used this on a mini road trip and couldn't imagine hitting the highways without one. [Image: b364657809d0ddfa51a23b100e1da463.jpg]
Sent from my SM-G925P using Tapatalk
I have the same throttle assist. Great little device and does help with tired hands. Only about $11.00 most bike stores stock something similar. Fits in seconds using a rubber band round the standard grip or Grip Puppies then the plastic piece goes round it and will tighten onto the grip with normal throttle action. You can rotate it clockwise out of the way if not wishing to use it.
10-23-2015, 05:18 AM
SCCBrider_imp Offline
Threads: 27
I just got my Go Cruise in the mail today. Used it as I went to go get some gas. It will definitely be an asset on those long trips on the highway. Not bad for the price. Just 29.51, on Amazon. Sold by Powersports911.
10-26-2015, 08:05 AM
  Handlebar control symmetry Uncle Sixer 17 1,727 08-07-2025, 05:24 AM
  Anyone using the Kaoko throttle control? milkmaster_imp 50 3,344 07-12-2023, 06:45 AM
Last Post: milkmaster_imp
  KAOKO cruize control ozigoo 6 542 05-27-2020, 01:14 PM
Last Post: 17-CB-002
  ATLAS Cruise peterbaron 21 1,424 10-16-2019, 06:27 AM
  Foot Control Relocation Kit reinie_imp 6 625 01-10-2018, 12:13 PM
Last Post: Nightengale_imp
  Kaoko Cruise Control Kit 17-CB-002 12 854 07-19-2017, 02:10 PM
Last Post: Nortoon_imp
  Brake Away throttle control Razor 25 1,666 07-16-2015, 10:05 PM
Last Post: redbirds_imp
  Brakeaway Cruise drodg33 9 838 06-07-2015, 03:34 AM
Last Post: 1100rider_imp
  throttle lock (aka cruise control) GregMcK_imp 4 387 08-09-2013, 08:52 AM
Last Post: FUZZY_imp
  Bazzaz Fuel Control ***Update 6/7/13*** thumper_imp 24 1,975 06-10-2013, 11:10 PM
Last Post: Guth_imp
