Tall seat for 2017+ CB1100
E11even_Hunnit Offline
California
Threads: 5
Likes Given: 33
RE: Tall seat for 2017+ CB1100
As far as having your pegs slightly relocated to accommodate your legs, preferred riding ergos, these might help
https://www.ebay.ca/itm/Black-Shadow-Fro...SwwkhgIsIE
Not as drastic as aftermarket rearsets ofcourse, but also not $800 like the cheapest set of rearsets available for our bikes
03-26-2021, 04:20 AM
Houtman_imp Offline
Threads: 115
(03-26-2021, 02:51 AM)pdedse_imp Wrote:
(03-26-2021, 02:12 AM)Houtman_imp Wrote: Some of us are getting old enough to use depends for extra padding on our bikes !
Cool beans! Using those would take away the unsightliness of the bleacher pads! Do I wear them under or over my mc pants?
If you need them just for bladder control wear them inside you mc pants , if for a more custom look wear them outside your mc pants.
After my prostate removal I had to wear depends for about 10 days , when I bought a pack of them in Walmart the young girl in the checkout looked kind of funny at me .
I told her "these are for my grand father " I thought she somehow did not believe me...
03-26-2021, 05:09 AM
j3gq_imp Offline
Threads: 78
Have you ever been caught speechless, Houtman ?
03-26-2021, 05:23 AM
Houtman_imp Offline
Threads: 115
(03-26-2021, 05:23 AM)j3gq_imp Wrote: Have you ever been caught speechless, Houtman ?
Only when I saw the first 2013 CB 1100 on the show room floor ......
03-26-2021, 06:28 AM
peterbaron Offline
Likes Received: 575 in 312 posts
Likes Given: 962
.............. , if for a more custom look wear them outside your mc pants.
........ , when I bought a pack of them in Walmart the young girl in the checkout looked kind of funny at me .
......[Image: 481ef26aa29cc908961e761038c1b8e4.gif]
P.S....smart statements
03-26-2021, 06:51 AM
Run Away_imp Offline
Threads: 1
(03-25-2021, 03:02 PM)pekingduck_imp Wrote: Spending $500-$1000 dollars for an off-the-shelf "custom" seat sounds like a lot, especially since there is no way of knowing if it will suit you.
I have the same complaint, and remedied it on my 2013, 2014, and 2017 models in the same way, by having an inch of foam added under the stock cover. My local upholsterer was able to sew an additional strip along the bottom of each side so there is material to staple into the base. I've had 3 CB1100 seats done, and all were done within a week, and under $100.
Thanks for the pictures, I was imagining a visible strip of material along the bottom but that seems like a darn good option for me.
Regarding pegs, I do have a set of cheap lower pegs on the way. Just cheap eBay ones so I can see if I'm okay with the reduced ground clearance, and play with putting them straight down, or down and back.
I'll probably cut up some foam kneeling pads I have left over from home renos and give those a try....once it warms up. It freaking snowed last night! Angry
Also came across another interesting tidbit on the Daytona website regarding the seat differences
https://www.daytona.co.jp/products/single-74924-parts
"Since the tank shape of the CB1100EX / RS model is different, there will be some wrinkles on the skin at the tip of the seat (the part that comes into contact with the tank) when it is installed."
To me that implies that the seats can be swapped between models, and that the RS/EX tank might be longer than the older models?
03-26-2021, 10:01 AM
Tev62 Offline
Threads: 33
Likes Given: 95
(03-25-2021, 11:25 PM)Ben70_imp Wrote: Tev62, there are adjustable pegs out there, someone may chime in with a brand but the search function may help.
I got some Knight Design aluminum ones a few years ago that I like. They had too much "tread" for me so I stuck em in a vise and belt sanded them down a bit and smoothed the edges with a file, which also gave me an extra 1/4 inch or so but still good traction.
Either option eliminates the peg feelers. Good luck.
Ben
Cheers for that Ben, I have a shorter leg so an OK, I was just wondering if that was an option for thre OP. Thumbs Up
03-26-2021, 06:12 PM
dhubbard422_imp Offline
Threads: 1
(03-25-2021, 01:42 PM)Run Away_imp Wrote: Hey all,
I've got an '18 CB1100RS. I'm 6'2" with a 33 inseam and I'd like to unfold my legs a bit. I'm coming up empty so far finding a solution I like.
Here's my stock seat:
[Image: 3f485ea708768ed971eee7939dac1dce.jpg]
What I really want is a K&H high seat, but they only make those for the 14L and 17L tanks with seams. For the seamless tanks, [url=https://store.kandh.co.jp/products/list?category_id=56]they only offer a MID seat.
I've emailed K&H directly, but they have declined to make a custom order.
I've emailed Mr Takashi at Samurider, and he says I could get the Ohkawa Works seat custom made 1" taller. This option is fairly expensive and would take over 2 months to get here. Cost is about $1000 CAD.
[Image: 16ce08a80a323385a263a899bc58896e.jpg]
I've found Luimoto here in Canada that [url=https://www.luimoto.com/?c=1&my=637&p=1208]make a nice looking cover for the 17+ seats. I was thinking possibly they could make a custom cover with extra length on the sides, and I could add foam myself, or have a local upholster do the job? Rough estimate of $500 CAD for the whole job, plus I sacrifice my stock seat.
I could have a local shop modify my stock seat. Unknown cost and time frame, also the potential to not be done as nice. Again, this becomes my only seat.
I could have Sargent Cycle custom make a seat. Unknown cost, likely a longer time frame due to shipping. I sacrifice my stock seat, but the end result is probably pretty nice.
Finally, I've been poking around Yahoo Japan auctions and found a bunch of second hand K&H seats, as well as Daytona, and OEM Honda seats.
I could buy a backup 17+ seat and use it as my base for a custom seat, which means no downtime. Cost for a RS seat is about $450 CAD shipped, which is about $100 cheaper than new at the dealer.
Or I could buy a used K&H high seat for the '13-'16 bikes and have it modified slightly to fit my bike. Cost for these seats is around $600 CAD shipped.
My question is, does anyone know where the seats differ?
If the older seats are longer in front, I can peel back the cover, trim them down as needed and fold the excess back under and secure it. If they're not, it's not such an easy task to add material.
Anyone know?
I've seen a few threads relating to swapping the newer tank onto the older bikes, but not many people mention what happens to the seat fitment during this project.
Some threads I've looked into with some info I've found useful
[url=https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwj4-fWag83vAhVWGs0KHW1dBsAQFjAAegQIBhAD&url=http%3A%2F%2Fcb1100forum.com%2Fforum%2Fshowthread.php%3Ftid%3D12152&usg=AOvVaw021ixtULMoMXh1q0xEh7Cc] K&H High Seat for 2017 EX
[url=http://cb1100forum.com/forum/showthread.php?tid=14035]Deluxe seat on a Standard
[url=http://cb1100forum.com/forum/showthread.php?tid=15242]Tank interchange
[url=http://cb1100forum.com/forum/showthread.php?tid=10544]2017 Gas Tank on a 2013?
An interesting side view of the 3 different tanks offered. Pictures from the K&H website.
[Image: 067f8917add6dc43383d8c2683b6efaf.jpg]
Top left is the 14L tank, middle right is the 17L, and bottom left is the 17+ seamless tank.
I did have Sargent build a taller seat, basically a flat seat. I think it turned out quite well. I also installed a set of lowering foot pegs. That combo transformed my riding experience. An hour long ride that was literally a pain in the knees, is now pain free.
YMMV, but I found the work Sargent did to be quite good and affordable.
HTH, Don
04-30-2021, 01:44 AM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
[/quote]
HTH, Don
[/quote]
Very nice. Could you post pics of the seat and pegs (and cost)?
04-30-2021, 03:23 AM
Threads: 1
Apologies for the significant delay... Sargent charged me about $250 USD.
The seat Sargent built:
The adjustable footpegs pictured are made by LSL. I have an extra pair of lowering footpegs made by Knight Design:
http://www.knightdesignllc.com/Products/...-Pegs.html
The pair I have are Silver Anodized with Sidetrax tread and I'd happily sell them at a nice discount to someone on the forum. They fit well on my '13 and they gave considerable knee relief.
05-19-2021, 05:59 AM
  Tall Riders and Comet striped shield Nightryder22_imp 11 1,086 04-08-2022, 09:28 PM
  2014 CB1100 EX Seat Fit On 2013 and Older Bikes SUPERCRUZ_imp 36 2,065 06-05-2021, 08:14 AM
  Part No for 2017 EX low seat? p200_imp 17 1,285 05-25-2021, 11:27 AM
Last Post: p200_imp
  improved seat and 3 cm higher SEAT. the best reform Alfgaxatico_imp 1 294 04-25-2021, 04:47 AM
  Tall Windshield Nortoon_imp 45 3,102 01-01-2021, 10:47 AM
Last Post: White Dog_imp
  Flasher - Buzzer installation on a 2017 CB1100 17-CB-002 12 911 01-15-2019, 12:26 PM
  Whitehouse Seat for 2017 EX tommymck 6 531 08-01-2018, 09:46 AM
  K&H High Seat for 2017 EX cookiemech 29 1,973 07-14-2018, 11:51 AM
Last Post: af_one_imp
  2017 seat baxtercat_imp 1 246 12-20-2017, 02:10 AM
  Corbin seat and back rest for cb1100 mdharne_imp 14 1,044 12-04-2017, 03:31 AM
Last Post: Mscb1100_imp
