Spare connectors/Oxford heated grips
peterbaron Offline
Likes Given: 996
RE: Spare connectors/Oxford heated grips
http://www.cycleterminal.com/hm-sealed-series-090.html
That extra 4 pin connector is a female, see post 2 ??
12-28-2020, 12:19 PM
White Dog_imp Offline
Threads: 59
(12-28-2020, 12:19 PM)peterbaron_imp Wrote: http://www.cycleterminal.com/hm-sealed-series-090.html
Correct. The pics of the connectors on the link you sent are reversed. The extra 4 pin connector wired to bike is the female and the insert connector is the male.
12-29-2020, 09:03 AM
tdbru Offline
Threads: 13
Likes Received: 40 in 22 posts
Likes Given: 11
Peterbaron, White Dog,
thanks for this post. has helped me find the connector on my 2014 std behind the tool box. I ordered the 4 pin male connector. according to the wiring diagram for after 2013 standard, this connector goes through fuse G which is 10A. I plan to run oxford heated grips, which are rated at 3.6 A. i also want to run a power port for my GPS which I suspect takes very little power. this also feeds the meters on the dash, and the turn signals. I put LEDs in the turn signals to increase brightness and reduce current draw. Anyone know what the meters draw for current? I think 10A should handle everything, just checking.
thanks again,
tdbru
04-18-2025, 08:40 AM
peterbaron Offline
Likes Given: 996
Modern car clusters should average around 1-5 amps, so I would guess that CB clusters are much lower, although I don't know the technical details.
04-18-2025, 10:02 AM
  Fork Gaiters and Heated Grips tdbru 20 3,067 05-02-2025, 11:16 PM
  connectors rich_imp 1 318 04-16-2021, 11:27 AM
   HEATING GRIPS ICON HONDA ORIGINAL NON-OPERATING CB1100 ex 2015 EUROPE. COMPLAINT TO Alfgaxatico_imp 16 1,865 12-10-2020, 07:35 AM
Last Post: Alfgaxatico_imp
  HEATED GRIP HONDA ORIGINAL - CB1100 ex 2015 Alfgaxatico_imp 9 750 11-21-2020, 09:45 AM
  hand guards and heated grips misterprofessionality 33 2,406 11-16-2020, 10:06 AM
Last Post: mrded_imp
  thicker grips active1951_imp 15 1,189 08-04-2020, 12:55 PM
Last Post: gmike_imp
  Making closed end grips work on the CB Skypilot_imp 6 646 05-18-2019, 10:40 AM
  OEM ONLY HEATED GRIPS peterbaron 4 585 10-09-2018, 10:59 AM
   Good grips for CB1100? Which ones are you all installing? rdtshaw_imp 61 4,520 08-06-2018, 11:47 PM
Last Post: itstuantran_imp
  Threw on Rizoma grips and bar ends. silascopathic_imp 9 806 06-01-2018, 02:23 AM
Last Post: Mandrau_imp
