Brake light for front brake only?
You can do whatever you want with your bike. You're going into the dealer and have him replace the wiring harness, or pinch it with a pliers. That's your choice, but it will likely come off again because it's a bad design.
I like my Gorilla Tape fix and I am sticking with it. Big Grin
(08-23-2013, 02:01 AM)meowguy_imp Wrote:
(08-23-2013, 12:57 AM)Deanohh_imp Wrote: The purpose of the switch on the front brake lever is to turn on the brake light when you pull the lever. Make sure the wires are pushed on the switch all the way and if it still doesn't work, take it in under warranty.
That was it. One of the connectors was completely off. I will have to make this one my checks before getting underway in the future.
Thanks all.
Thanks all.
[/quote
Usually just a pinch with a pair of needle nose pliers will do the trick no need to add tape which will just fall off and disconnect again.
Scientists have proven that duct tape works very well for almost everything except it is absolutely no good for, believe it or not, ..... ducts.
(08-24-2013, 12:12 PM)Deanohh_imp Wrote: Scientists have proven that duct tape works very well for almost everything except it is absolutely no good for, believe it or not, ..... ducts.
I am going to look at squeezing instead of using tape. I try to be reasonable, but I do like tape.
I would say the problem would be solved with a click in style connector.
It needs to be checked prior to each ride, and at intervals during a long ride because this is a critical safety feature.
  Brake light jiggle Southwend 9 901 06-01-2025, 05:57 PM
Last Post: Southwend
  Rear brake pad replacement LongRanger_imp 39 3,620 05-03-2025, 10:45 AM
Last Post: Delphisa
  Brake Pads... Simplified Yata-Garasu_imp 20 1,860 03-02-2025, 08:28 PM
  Front ABS Brake"Rain Stick" noise bflint 3 463 07-12-2024, 08:36 AM
Last Post: Race_ca1
  Rear Brake Pedal Adjustment Gone in 60 12 1,130 04-04-2024, 08:18 AM
  Brake fluid flush CB1100@2013: photos valkyrie_rider_imp 0 247 02-13-2024, 10:28 AM
Last Post: valkyrie_rider_imp
  Front brake inconsistent resistance ChiefJP_imp 16 1,374 06-14-2023, 07:46 AM
Last Post: bvictory_imp
  Sqealing front brake thop_imp 10 979 06-14-2023, 07:34 AM
  Synthetic Brake Fluid Wagonpeddler_imp 3 378 02-18-2023, 07:49 AM
  Front brake lever ROCK hard ichiban_imp 37 3,854 02-10-2023, 10:54 PM
