KNOCKING SOUND - HELP!!!
seems to be but now i am thinking that i should just replace the bearings all around just to be safe
(11-17-2013, 06:35 AM)silascopathic_imp Wrote: Hey friends,
so this morning i spent 3 hours trying to troubleshoot this knocking sound coming from my front wheel.
I have narrowed it down to the wheel bearings or the wheel balance.
i will hear a constant cyclical knocking sound in neutral, in gear, when the bike is on or off. I removed the calipers from the rotors and the sound is still there.
I removed the front fender and the sound persists.
I removed the wheel and the forks and reinstalled per the instructions in the service manual.
First i did the forks and tested. The issue persists. Then i removed the wheel, the gaskets and the bearings and the middle tube thing. I put them all back in correctly and took the bike for a ride. The sound was GONE!
I went out for a ride and 10 min in, the sound came back.
Here is what I am thinking
When I originally had my wheel powder coated, i did not replace the bearings (even though the service manual says to) because the bike was under 1000 miles. I recently had my front wheel balanced and the guy stated that it didn't need weights. He just re aligned the tire dot with the stem valve.
The sound is getting progressively worse.
Do you think I should get new bearings and take the wheel back for another balance?
I am not sure if this is doing damage to the wheel, but I am not riding it until its repaired
I need all of your expertise.
please help a brother out!
Thanks
Go to YouTube and plug in { Chris Harris } or Chris Harris motorcycle. He's a real pro motorcycle mechanic.A stickler for
doing things right.He lives up in New England and has his own
Motorcycle shop next to his home.He's a certified BMW mechanic.
he has The best little video of how to change a tire and balance.
The exact proper { make no mistake } way to handle the job.
He has a lot of Videos.But they are titled.The title explains what the
video shows.
I just went there.he has {344 videos } and it's the one :
BMW Service - Tire Mounting and Balancing { 20:23 }
(11-20-2013, 05:54 AM)silascopathic_imp Wrote: seems to be but now i am thinking that i should just replace the bearings all around just to be safe
Silas - any updates yet?
  Knocking noises; vibrations in the handlebar; oil sipping at valve lid gasket TheLegend 47 5,670 11-16-2025, 12:01 PM
Last Post: TheLegend
  2014 rear wheel knocking noise dunebuggy_imp 7 959 08-05-2024, 03:33 AM
Last Post: Yata-Garasu_imp
  Sound check what wrong tory_imp 3 425 03-30-2022, 12:33 AM
Last Post: 1973cb750
  Best Honda CB1100 Exhaust Sound RS EX? charles2021_imp 1 267 05-27-2021, 09:47 AM
Last Post: bioman_imp
   Ticking / clicking sound after oil change simplest2remember_imp 12 960 02-03-2021, 01:32 AM
  Chain making clanking grinding sound. bflint 36 2,782 11-09-2020, 05:04 AM
Last Post: LakeWylieJoe_imp
  Ticking Pinging sound Maurice_imp 17 1,236 05-05-2020, 11:19 PM
Last Post: alprider
  Engine sound kklandzw_imp 3 413 11-17-2019, 04:01 PM
Last Post: zirconxi_imp
   Engine Sound Changed After Service EarsOnWheels_imp 19 1,175 07-28-2017, 11:07 AM
  'Whine' sound/problem ride4now_imp 17 1,172 10-10-2016, 09:43 AM
Last Post: ride4now_imp
