Bush mechanic - a little Gravel Rash removed
Bike looks great, pterodactyl. Were there scratches in the cover? How'd you get them out?
Wise words from the Spaceman. Don't be too hasty.
(04-30-2014, 08:14 AM)Cormanus_imp Wrote: Bike looks great, pterodactyl. Were there scratches in the cover? How'd you get them out?
Rubbed them out with ever decreasing grades of wet and dry (1200 the last). Not deep enough to need a file or compromise the integrity of the casing, but very ugly. If your bike is unfortunate to suffer "drop rash" it is not a hard job, just takes patience. If anyone is tempted, it is best to rub the whole casing back rather than try to patch.
Better still take ferret's advice Smile
And thanks Spaceman, I'll take that on board.
Thank you kind sir.
By the way, wasn't there a wonderful film called Bush Mechanics?
Thank you kind sir.
No worries. There was a TV doco, a little offbeat but kinda engaging:
http://www.abc.net.au/tv/documentaries/s...359476.htm
A short YouTube excerpt:
[url=http://m.youtube.com/watch?v=H-tsKPlDn7U]Bush Mechanics
Fit the Staintune
[Image: ec7fd6a84a403b08025301a8befa0863.jpg]
G`day Pterodactyl, I see you have a Staintune fitted and wonder what clearance you have between the bottom shock absorber mounting bolt and the exhaust itself with no rider whilst on centre stand or sidestand. I had one sent through by my brother and the clearance seems minimal after comparing with the original unit which has a factory deformation in that area to allow a large clearance. Photo would be greatly appreciated.
Regards
(05-11-2014, 07:11 PM)Tyke57nz_imp Wrote: Fit the Staintune
Regards
[Image: 7aa2a80ed450347c3d1dce2c66e70d51.jpg]
Side stand
[Image: fb50c90a842d1619465b20bab3ecd2c2.jpg]
Centrestand
Clearance is about 5mm, by eye. If you want precise will measure tomorrow. When the suspension is working there should not be a problem. I have applied a deal of force and can't put the muffler against the suspension. I think you would have to have a severe drop for contact to occur. Monitoring of the mounting bushes should be part of routine checks. On the other hand if you want to remove the lower shock mounting bolt then the Staintune would have to be removed. Not a big deal. There are a number of members on the forum with Staintunes and no reported problems. If I can be of any further help let me know.
If your Staintune lacks clearance near the shock, loosen all bolts (actually, completely remove rear bolt) and twist the entire muffler in order to reorient its positioning at the point where it attaches to the exhaust. You will eventually find a position which allows the rear of the Staintune to clear the shock by a nice margin and also seats the rear mount bolt and rear exhaust mount tab nicely with the rear factory mount point. I experienced the same issue and am OCD with respect to these things. I think what happens is that we're all happy to simply get the thing on at the first attempt...it is only later that we focus on the details (primarily how it hangs at the rear mount point). Again, I suggest you budget 15-20 minutes to the effort...twist it around and push it in and out as necessary at the point where the Staintune connects with the factory pipe, it is likely not bent or improperly manufactured...you just need to find the positioning which seats the Staintune correctly at both ends.
Regards
Side stand
Centrestand
Thanks for that, appreciate the time and effort. Was getting a bit late for me last night, will go out with a different mindset and get it sorted.
(05-12-2014, 01:26 AM)xpacpal1x_imp Wrote: If your Staintune lacks clearance near the shock, loosen all bolts (actually, completely remove rear bolt) and twist the entire muffler in order to reorient its positioning at the point where it attaches to the exhaust. You will eventually find a position which allows the rear of the Staintune to clear the shock by a nice margin and also seats the rear mount bolt and rear exhaust mount tab nicely with the rear factory mount point. I experienced the same issue and am OCD with respect to these things. I think what happens is that we're all happy to simply get the thing on at the first attempt...it is only later that we focus on the details (primarily how it hangs at the rear mount point). Again, I suggest you budget 15-20 minutes to the effort...twist it around and push it in and out as necessary at the point where the Staintune connects with the factory pipe, it is likely not bent or improperly manufactured...you just need to find the positioning which seats the Staintune correctly at both ends.
Thanks for the info, was running a little late and probably should have left everything in the box till today. Will go out with a different mindset and it will all be sorted. Cheers
(04-29-2014, 06:59 PM)Tortuga_imp Wrote: Hehe, he said "bush mechanic".
Smile
Pretty sure "Bush Mechanic" was The Spaceman's nickname in high school.
Wink
Watched the youtube link about "Bush Mechanics", they remind me of some people I know back in Louisiana, in fact, I have a cousin that is probably an alpha "Bush Mechanic". Big Grin
Bike looks great, Ptero. How's the arm?
  Who has removed their rear wheel? CB4ME_imp 6 466 09-09-2014, 03:40 AM
Last Post: Rocky_imp
