Bike won't start
My meter was so old that the battery corroded the circuit board. In other words toast. Bike still starts in neutral so I'll take it to Home Depot for a new one. Hope it's just a bad clutch switch.
Sorry to hear that CB. I've had it happen too.
(08-30-2015, 12:12 AM)CB4ME_imp Wrote: My meter was so old that the battery corroded the circuit board. In other words toast. Bike still starts in neutral so I'll take it to Home Depot for a new one. Hope it's just a bad clutch switch.
Hope it's just a bad connection
Let us know how you go. Good luck.
Fixed! The plug to neutral switch wasn't fully plugged in.
where? up under L/H switch assy or somewhere else?
The neutral switch is under the transmission on the right side of the bike. The service manual has a drawing showing all the switches and pointed to the left side of the bike just aft of the sprocket cover but it ain't there. But the drawing made me take off the sprocket cover to check. I quickly realized it had to be on the other side. I push the connector up, heard a click as it snapped back into place, and instantly knew that was the issue. (Clutch switch passed continuity test).
Great!!
Hmmm I don't remember seeing a switch on the right side. Exposed or behind a case?
In the '13 manual it shows it on the right side bottom. On page 1-27.
The EOP switch is close to it (engine oil pressure)
  High engine revs on start up CBX1000_imp 21 1,650 06-06-2024, 02:40 AM
  CEL after Jump Start rage91_imp 23 1,443 04-14-2023, 01:25 AM
  Won't start RLS_imp 5 416 05-12-2022, 05:58 AM
Last Post: RLS_imp
  CB 1100 won't start GeorgiaRider_imp 30 1,877 12-19-2020, 11:19 PM
  Low rattle on cold start. shahyaan_imp 22 1,424 11-30-2020, 12:01 AM
  Bike crank but wouldn't start. zirconxi_imp 67 3,555 04-25-2020, 01:37 AM
Last Post: White Dog_imp
  strange start pdedse 48 2,398 02-02-2020, 06:34 AM
  Won’t start? bsavoy04_imp 26 1,203 08-05-2019, 04:38 AM
Last Post: LongRanger_imp
  2014 Start - Cutoff Switch Question deltamark 16 1,180 04-18-2019, 06:23 PM
Last Post: flynrider
  Motorcycle doesn't start, high oil temperature indicator comes on Saarang_imp 17 1,103 07-20-2018, 07:14 AM
Last Post: SportsterDoc
