Well That’s a Fine Start
Thanks for all these checks, regarding the oil level check; to evaluate how much over the top mark it is place a 6 to 10 mm thick board on the ground on the place where the center stand is used, put the bike on the center stand with the board under the leg under the sight glass, this is the safest way to place the bike on the center stand at an angle without dropping it.
if the level is still too high with the bike on a lean the oil level needs to be lowered, take your time, think it through.
To do this the bike has to sit level without the extra board and a cold engine ( as you have done before ).
Best way to do this is to loosen the drain bolt, place a container with some newspaper under it and loosen the drain plug until the oil starts to run out, watch the sight glass while draining the oil and stop when the top level is reached, take your time and practice to screw the drain plug back in, re-tighten the drainplug and clean up any spills, done properly this should not be a messy job, slow flowing oil does not run along the ridges of the thread of the drainplug very well.
Do not re-use the drained oil, you don't want any contaminants in the new engine, simply not worth it.
If it was me i would clean the area to your satisfaction and go for a ride, if more oil presents itself let us know. and if all stays dry enjoy the bike as we all do, cheers.
Although quite unlikely, it is possible:
I picked up a motorcycle from dealership and by the time I got home I had significant fresh oil dripping out of the gear shifter seal. The seal failed.
The dealership picked up the machine and dealt with the issue.
I thought Max would mention this as he is pretty sharp Wink
The clutch cover does not have a gasket. It has a sealant (Three Bond 1207B or equiv.)
To me sounds like it was overfilled.
Found the leak…
It’s coming from this bolt it the photo. Should I tighten?
That's the main oil galley plug,( supplies the pressured oil to the crankshaft ) we need popgun's help here, good find mate.
Max, although it is shown on the parts fiche there appears to be no mention of it in the service manual.
Nothing in the torque spec section or the crankcase section. If it were mine I’d probably take it out, put some thread sealer on it and tighten it “securely”.
Maybe a better mechanic will chime in.
Google turned up this post from 2016 which had it seems a similar issue that did not have the repair documented so we don't know what happened ;
[url=http://cb1100forum.com/forum/showthread.php?tid=8487&page=2]http://cb1100forum.com/forum/showthread....487&page=2
Other than that a few plugs have o-rings, they have a groove close to the flange to hold the o-ring, another ( sideways view ) picture of the plug would help to find out if this is the case and if sealer has been applied and how much unless someone knows the answer.
However the dynamic balancer shaft ( just to the right with the clamping bolt) is very close by and it has a seal that weeps very slightly sometimes, worth a second look before taking the galley plug out.
  Start up idle / procedure? el duque_imp 5 359 03-29-2018, 08:39 AM
Last Post: el duque_imp
  Van asked me to have a word with you fine gentlemen. VLJ_imp 51 3,191 01-26-2018, 02:42 PM
Last Post: VLJ_imp
  Begining Motorcyclists: Start Slow or Get Right In It? specialist8 13 688 08-16-2017, 12:26 AM
Last Post: CA200_imp
  Bad start to the day 68lupe_imp 29 1,663 02-28-2016, 01:33 PM
Last Post: Randy B
  CB Cold Weather Start-Up Haystack_imp 18 1,107 01-24-2016, 03:17 AM
Last Post: Rocky_imp
  Digital Display - fine scratches ecka00_imp 14 767 07-11-2015, 06:41 AM
