Well That’s a Fine Start
Well no it wasn’t actually.
With under 500 miles on the odometer, I picked up my new to me CB1100 and arrive home after sixty miles to discover oil over the lower frame and exhaust on the right side. Haven’t ridden it since but wiped the oil away. No subsequent drips. Think it’s coming from the bottom of the main cover on the right. Still under Honda warranty so expecting them to collect early next week. Any ideas anyone?
First, check the oil filter. Sometimes the old gasket doesn’t come off with the filter and when a new one is put on there are 2 gaskets and leaks happen.
If it has a K&N filter. These are known to fail this and do what happened.
Check the drain plug for tightness.
Thanks… those areas are all free of oil. I was thinking it could be as simple as trying to torque to 12nm the clutch cover as that’s where it appears to be coming from.
Ok, maybe. Can you pos a pic or 2?
Oil filler cap is tight, and o-ring on it, right?
Yep that’s tight and completely free of oil. The uppermost area of oil is from the underside of the clutch cover.
The ride today was in warm conditions 22c with about 25 minutes of stop start riding… ie heavy traffic.
Just thinking, once a seal has been passed by oil is it compromised for good or would, it they were a tad loose, bolt nipping up help.
Im betting it's something silly. Loose drain plug, loose filler, maybe the breather from an accidental overfill. These bikes almost never leak.
It way be as simple as the previous owner spilled oil after refilling it, wiped of what he could, and it's just residual blowing up and back from riding.
How much oil does the motor currently have in it?
Thinking the same way as Pekingduck, this area is just under the filling plug and can be overlooked.
If the oil has been replaced ( 500k first oil change ) prior to you taking delivery it should be very new and clear, i would still check the level by putting the bike on the centerstand on a level surface, the sight glass should show the level ( cold and not running ).
Was the oil you wiped up dirty or clean?
Highly unlikely there is a leak and be careful with checking bolts, don't over tighten them.
Just to recap on the facts…
The drain plug is dry and no sign of oil is evident.
The oil filter is dry and no sign of oil is evident.
The oil fill cap is dry and no sign of oil is evident.
The sides not least the whole of the clutch cover is free of any oil.
The underside of the clutch cover is not free of oil and was when I found it quite wet.
The frame immediately below the clutch cover was wet enough to have a couple of potential drips… viscosity preventing it drip though.
The exhaust cover immediately below the frame which was wet, had oil on it.
The exhaust cover as it becomes the silencer had oil on it.
The oil although fresh was changed in May. The bike hasn’t been ridden and then subsequently sold.
The oil I found outside of the engine was very very slightly dirty.
(08-14-2021, 09:14 AM)max_imp Wrote: Thinking the same way as Pekingduck, this area is just under the filling plug and can be overlooked.
Cold… the sight glass is entirely full. Ie there is no discernible level.
  Start up idle / procedure? el duque_imp 5 383 03-29-2018, 08:39 AM
Last Post: el duque_imp
  Van asked me to have a word with you fine gentlemen. VLJ_imp 51 3,396 01-26-2018, 02:42 PM
Last Post: VLJ_imp
  Begining Motorcyclists: Start Slow or Get Right In It? specialist8 13 739 08-16-2017, 12:26 AM
Last Post: CA200_imp
  Bad start to the day 68lupe_imp 29 1,837 02-28-2016, 01:33 PM
Last Post: Randy B
  CB Cold Weather Start-Up Haystack_imp 18 1,205 01-24-2016, 03:17 AM
Last Post: Rocky_imp
  Digital Display - fine scratches ecka00_imp 14 857 07-11-2015, 06:41 AM
