OH NO! Did I just cook my rear disk!?
That happened on my st1100. Rotor was glowing red! Had to release pressure to release the brake pads from rotor. Flushed line and rebuilt caliper, New pads and good to go.
Sent from me......
Tink, the 0.008 spec is for the front rotor. The .012 is for the rear. Looks like you are good to me. And no, I don't know why it is different Smile
Well, new rear pads are on and brake fluid changed.
It seems like all is good now... but it still feels to me that there's some drag... Confused
I'll take her for a long ride tomorrow to assure the rear brake is happy now.
Here are the overheated rear pads:
Good luck Tink. Hope all's well.
Tink, my advice would be to do some trouble shooting before your ride. At least flush the hydraulic system with new fluid and check the pedal for binding. The rotor may not take too well to another overheat.
Cheers and good luck.
Sorry, I see you have flushed the system. Once again, good luck.
So far, so good. Thumbs Up
Went for a 100 ride today to Crystal Lake Cafe and back. Rear brake is functioning fine, no excess heating. Biker
Made darn sure my big foot was not resting on the brake pedal. Think I dodged a $$$ bullet this time. Still no clue as to why this happened, I'll assume "BIG FOOT" did it. Wink
Well, hope you got the mystery solved Tink and it was self inflicted rather than a mechanical issue. Funny when I test rode my brothers new Triumph T 120 I noticed the brake pedal was a lot further in from my foot,. Since he was riding my CB 1100, I quickly told him thru our intercom to keep his clod hopper boot off my brake pedal that some guys on the forum were having trouble with that.
I did it to TWO discs, warped them good, but didn't damage the pucks. If you look at the photo where the edge of the disc is visible, you can see the edge is a grey colour. Originally it was painted black. Smile Cooked right off (and in your case, things went a bit over board).
The main cause seems to be over sized Sidi adventure boots. Wearing my Tour Master boots does not lend its' self to riding the brake pedal. But I like the Sidi's much better so I took a big pipe wrench and bent the brake pedal in a few degrees (in my ever so humble opinion Angel I think it sticks out too much, much more than my other two bikes which does not help matters). Since I bent the pedal in this has not been a problem at all.
(05-27-2016, 09:56 AM)Rboe_imp Wrote: I did it to TWO discs, warped them good, but didn't damage the pucks. If you look at the photo where the edge of the disc is visible, you can see the edge is a grey colour. Originally it was painted black. Smile Cooked right off (and in your case, things went a bit over board).
BIG FOOT found!
You were on the right track, Rboe. Thumbs Up My Aerostich Combat Touring boots (made by Sidi) were the ones I had on when I found myself OVER covering the brake pedal.
Today I caught BIG FOOT red handed... as I was exiting the freeway I was working my way through some heavy mall traffic when I pulled in the clutch to downshift the bike lunged forward... your guessed it, I had my foot on the brake pedal applying pressure to the brakes without realizing it.
When I got home I adjusted the rear brake pedal position as low as it would go. After a quick test ride I could tell right away I liked the new position better, and hopefully BIG FOOT will not return.
Oh, and I have some Alpinestar touring boots that I'll wear from now on when I take the CB1100 out. Biker
This seems to be common. The same issue surfaced with my V-Strom when I first got it. Riding with regular shoes on, no problem. Put on my steel-toed work boots, problem. I didn't cook the rear brakes, but noticed the bike acted like it was pulling an anchor and every time I pulled the clutch in to shift, the bike dove down. Problem was the larger boot engaged the rear brake.
So now I test every time I have a new boot or bike. I adjust the brake lever down as far as I can and try to train myself not to rest my toe on the brake when riding.
Glad you found it. Experience is the best teacher.
Don
  New Rear Tire and Rear Brake Pads memphismike_imp 5 569 06-11-2018, 09:35 PM
  S100 safe on tires and disk brakes? meowguy_imp 9 635 07-27-2014, 02:43 AM
Last Post: Mr Jangles_imp
