10-15-2016, 02:27 AM
Just wondering if any of you kept your battery on a tender?
Battery Issue
10-15-2016, 03:16 AM
I keep my ST1300 on one all the time as I don't ride it much(same battery as the CB). As soon as riding season is over the CB will be on one. Some here keep them on all the time
10-15-2016, 04:45 AM
(10-15-2016, 02:27 AM)Blockhead_imp Wrote: Just wondering if any of you kept your battery on a tender? Whenever I am not riding my bikes are on tenders. They get plugged in when I come in from a ride before I even take off my helmet. Just happened on the CB. Rode some curvy roads for an hour, pulled into the garage, turned off the ignition, climbed off and plugged her in. Then came in the house to remove gear. I got 5 years out of first ST battery, installed a new Japanese Yuasa in Nov 2011 and it's still going strong 5 years later as of next month. (knock on wood). CB battery is only 2 1/2 years old.
10-15-2016, 05:02 AM
10-15-2016, 07:07 AM
If it's going to sit for any extended period of time. So, no.
10-19-2016, 08:06 AM
This just happened to me, a couple of weeks ago. Identical symptoms. Bike is nearly always on a tender. 2013 Standard with about 9000 miles. Fired up just fine in the garage, again after gassing up. Then, just as the OP stated, barely cranked, would not start. Got a jump from the Auto Club and fired up fine after that. Checked battery voltage (bike off) and showed about 13V after the ride, which is excellent. Bike was putting out about 14.1V at idle so alternator is good.
Must be a bad batch of batteries because we all seem to be having same issue at about the same time. I thought perhaps the connection was not tight but that settles it for me; a new battery will be on order soon. Weird. |
« Next Oldest | Next Newest »
| ABS , speedometer and battery | Walter | 10 | 815 |
05-02-2026, 01:29 AM Last Post: Walter |
| Yuasa Battery Life | dave | 28 | 2,753 |
04-01-2026, 04:44 AM Last Post: Tev62 |
| Help from the hive mind: Intermittent Starter Issue (2017) | JRD | 10 | 582 |
01-30-2026, 02:16 PM Last Post: JRD |
| Rattle on right side exhaust / battery | CB1100i_imp | 4 | 706 |
04-18-2025, 02:48 AM Last Post: CB1100i_imp |
| Battery jumper | the Ferret | 14 | 1,188 |
10-28-2024, 10:58 PM Last Post: the Ferret |
| CB1100 SA-E 2017 Battery | Davidjill_imp | 1 | 297 |
08-01-2024, 02:33 AM Last Post: Gone in 60 |
| Shifting issue | Cormanus | 31 | 2,443 |
05-15-2024, 12:59 AM Last Post: the Ferret |
| wonder battery | The Gecko_imp | 58 | 4,904 |
02-19-2024, 11:20 PM Last Post: mvk24_imp |
| Could old/low battery trigger misfire and engine light? | Motorsport3_imp | 13 | 1,299 |
12-17-2023, 08:41 AM Last Post: Jgarciajr40_imp |
| Arrow Slip on issue - stock gasket didn’t fit | Ddawg1144_imp | 4 | 481 |
02-21-2023, 07:51 AM Last Post: Charlie Bravo_imp |
