BackOFF Brake Light Module
(11-01-2016, 03:38 PM)Ulvetanna_imp Wrote:
(11-01-2016, 09:23 AM)Hawkeye_imp Wrote:
(11-01-2016, 02:56 AM)Ulvetanna_imp Wrote: I installed a BackOff module. All the wires can be accessed directly under the document compartment along the left frame rail. I flat-mounted the module on the forward part of the rear fender, using the sticky tape or whatever was provided but also secured it with a silicone band I had laying around from a GPS mount for a bicycle. I guess I need to go get you an image...
[attachment=5525]
Ulvetanna,
Many thanks for your much appreciated details and photo; they are very helpful!
May I ask if you soldered the wires, or did you use another type of connection?
Thanks again!
Ulvetanna,
Thanks again! As I recall, I used the standard crimp-type connectors on all connections. I like this module, I really do feel it helps get a bit more attention. I ride in a lot of traffic so it seems to be a good modification.
Ulvetanna,
Ulvetanna,
Thanks for your response.
I researched a number of flashing brake light devices; many claimed to have the most advanced and/or best flashing patterns, but the BackOFF appealed to me the most.
Thanks again for your help!
[attachment=5525]
Ulvetanna,
Thanks again!
Ulvetanna,
Ulvetanna,
Ulvetanna,
Outstanding, let us know how it turns out.
I fitted one of these back in 2014. Works well with standard globe and has many programmable features.
http://www.ebay.com.au/itm/G1-CAR-MOTORC...Swal5YEQvO
(11-03-2016, 12:18 PM)Tezza_imp Wrote: I fitted one of these back in 2014. Works well with standard globe and has many programmable features.
30 bucks, not bad at all.
  Brake light jiggle Southwend 9 954 06-01-2025, 05:57 PM
Last Post: Southwend
  A maze with no exit (brake light wiring) misterprofessionality 35 2,424 04-06-2020, 11:06 AM
  running light and brake light Ennsync_imp 3 448 01-02-2019, 11:24 PM
  Bike fell over, broke the front brake lever and bent the rear brake jlouis976_imp 24 1,828 09-14-2018, 12:35 AM
  Backoff XP Installed Ulvetanna_imp 0 186 06-22-2016, 02:00 AM
Last Post: Ulvetanna_imp
  Front brake light switch iffy Ulvetanna_imp 0 172 06-12-2016, 10:38 AM
  Front brake and brake light problem Krupator_imp 8 696 05-31-2016, 10:26 AM
  Brake light for front brake only? meowguy_imp 13 948 08-24-2013, 09:16 PM
Last Post: meowguy_imp
  is it easy to adjust the brake light sensor? 12cb96vfr_imp 3 437 07-19-2013, 02:31 PM
Last Post: 12cb96vfr_imp
