A petrol (gas) question
omg...this kind problems i like to have too....smile.... i guess i prefer our gas here
If you can find some alcohol free gas in your area, it lasts a lot longer without gumming up. Over the winter is no problem. I get a few more mpg's when I use it, added bonus.
I had never thought the poor mileage on the first tank after winter storage was due to the fuel stabilizer. In this neighborhood, winter storage is four to six months. I had always chalked it up to evaporation. Pump gas has a measurable percentage of 'low boilers' that evaporate fairly quickly. Less fuel burns to get to the "I need gas" point on the gauge. Compounding that is that the remaining mix is ... well ... 'gunk'. On my personal bikes, I have been known to drain the tank and pour the 'gunk' into my pickup truck.
A trick we used when we had demo bikes and others stored at the dealership*, was to use 100 octane avgas. It's not legal for street use, but enough to keep the system wet and start a bike for a customer. (Also, the bike will run REALLY well on it.) Avgas is specified to remain stable for six months. Those 'low boilers' could be a problem in an aircraft at higher altitude by causing vapor lock. Something not of great concern in a vehicle.
*A short stint as Sales Manager.
jim
(09-20-2017, 11:01 AM)tinboatcapt_imp Wrote: I had never thought the poor mileage on the first tank after winter storage was due to the fuel stabilizer. In this neighborhood, winter storage is four to six months. I had always chalked it up to evaporation. Pump gas has a measurable percentage of 'low boilers' that evaporate fairly quickly. Less fuel burns to get to the "I need gas" point on the gauge. Compounding that is that the remaining mix is ... well ... 'gunk'. On my personal bikes, I have been known to drain the tank and pour the 'gunk' into my pickup truck.
jim
Avgas is extremely stable compared to auto fuel. Unfortunately, using it in a modern vehicle could be disasterous. It gets its high octane from large amounts of tetraethyl lead, which will destroy catalytic converters and oxygen sensors in short order. Even in older bikes, long term use in an engine that doesn't have high compression pistons will eventually lead to unburnt lead deposits gumming up the valves.
That said, I used to use avgas quite successfully in my old Mercury convertible with a high compression V8 (originally spec'd for 98 octane auto fuel). Ironically, at the same time I had to burn 87 octane auto gas in my old Cessna with a low compression engine (originally spec'd for 80 octane avgas).
I've always attributed the drop in winter mileage to evaporation...never considered if the stabilizer had an effect. I use Seafoam like several others here.
Just as a point of discussion, not criticism...I don't think it's strictly legal to use untaxed offroad fuel in road-going vehicles. Not that anyone would ever check a motorcycle for taxed fuel. But, for example, using red-dyed home heating oil in a road-going diesel that's supposed to be burned taxed green-dyed diesel is a no-no.
Flynrider warns that leaded gas (avgas) harms catalytic converters and o2 sensors.
Stichill points out that it is illegal to use untaxed avgas on the roads.
It is true to both counts: it is illegal to use avgas on the road, and it does contain some TEL. For the shop we used a very small amount in the tank just to keep the tank and system 'wet'. That small amount would be highly diluted when the tank was filled with taxed, government approved petrol. The fuel is 'low lead' and not as heavily laden as the leaded gas of the 60's.
The small amount was sufficient as the bikes were stored inside heated space so condensation was not a problem. They all fired right up when needed in the spring.
I don't suggest that you regularly run the bike on anything but what can be dispensed from a station pump. Sorry about the confusion. One low mileage tank fill, at the start of the season isn't critical.
jim
Something interesting, tinboatcapt, that I remember from a research paper I wrote on the detrimental effects of low-lead gasoline on engines designed to run with leaded fuel, is that the octane-boosting properties of TEL are not linear. There is a relatively large octane boost for the initial amounts of TEL, but further octane increases require ever-higher concentrations of TEL. So that seems to fit your impression that a small amount of leaded avgas would have a larger-than-expected effect on the "virgin" unleaded fuel in the tank.
(09-21-2017, 11:06 AM)tinboatcapt_imp Wrote: Flynrider warns that leaded gas (avgas) harms catalytic converters and o2 sensors.
jim
Actually, it's called 100LL (low lead) because it has less TEL than the green 100/135 avgas sold in the 60s and 70s (primarily for huge supercharged radial airliner engines). The TEL content of 100LL is about 10 times the amount found in the old leaded regular auto fuel.
I agree that heavily diluted and not used as a regular fuel, it's unlikely to damage exhaust components. I only posted as a warning to those who might try filling up their tank with 100LL avgas as a storage strategy.
jim
Interesting. My chemistry is polymers, and it's ancient knowledge.
jim
  Smell of petrol (gas) simplest2remember_imp 3 282 04-25-2015, 09:38 PM
