11-09-2017, 05:21 AM
Use what you like. Your bike doesn't know the difference and you won't damage anything. Personally, I stick to the book and try not to overthink it.
ENGINE OIL
11-09-2017, 06:32 AM
(11-09-2017, 03:50 AM)Nortoon_imp Wrote:(11-09-2017, 01:30 AM)Rocky_imp Wrote: The owners manual says to use 10w30 so that's what I use. That's what the Owner's Manual says, but my Honda dealer only stocks jugs of 10W40 Honda oil. I used it for 33,000 kilometers on my CB500XA with no problems. So it should be alright for the CB1100 EX. The jugs are 1 US Gallon 3.8 liters. Which is the perfect measure according to the service manual for an oil change without a filter change. But who changes the oil without replacing the filter. However given that difference is only 1/10th of a liter, the jug will probably do. If not, I will probably buy a quart for top ups. I’m surprised that is the only weight oil your dealer carries since ALL Honda street bikes starting Jan 1, 2007 have been spec’d to use 10W30. Probably more an emissions thing than anything else, but that is what Honda spec’d. My 2006 ST 1300 calls for 10w40. The 2007 Honda ST 1300 which is the exact same bike except for color calls for 10w30. Btw I use 10w40 in the ST and 10w30 in the CB as spec’d. My dealer carries both. Also both bikes call for 4.1 qts when doing an oil change with filter. I dump the gallon jug in each and call it a day. Got 100,000 miles + on the ST and 36,000 miles + on the CB, and it seems to be working out ok.
11-09-2017, 07:09 AM
My OEM Honda Service Manual (and I think also the owners manual) suggest different oil for 2 different temperature ranges:
15°C and below: 10W-30 10°C and above: 10W-40 As most motorcycle are only ridden in the season, when it's not too cold, it makes totally sense to the shops, to provide just 10W-40, same here in Germany. Also these ranges do fairly overlap. I used 10W-30 during the dark time of the year and 10W-40 from May to October. However, I don't think, it's critical and either will work.
11-09-2017, 07:26 AM
Here, where, according to the manual, temperatures ought to dictate 10W-40, dealers offer oil change ‘kits’ with 4 litres of Honda 10W-30 and a filter. Go figure.
11-09-2017, 07:34 AM
"Also both bikes call for 4.1 qts when doing an oil change with filter."
----------------------------------------------------------------------------- I think that's more of a marketing gimmick than anything. Prods us into buying that extra quart unnecessarily.
11-09-2017, 11:36 AM
I have two hard and fast rules concerning oil:
1. Any oil is better than no oil. 2. Oil is much cheaper than engines. I use what is convenient. Note that most owners manuals have a large overlap of 10W-30 and 10W-40 for temperatures at which they are recommended. This means they will both work in the broad band of temperatures when most riding is done. jim
11-10-2017, 04:06 AM
(11-09-2017, 07:34 AM)Blockhead_imp Wrote: "Also both bikes call for 4.1 qts when doing an oil change with filter." There are only .95 liters in a US quart. So you get 10 top ups and we only get 9 1/2. ![]() Either way, if you want to be able to rely on the sight glass you need the extra 1/10th of a quart, unless the jug is enough. And it may be if 1/10 of a liter or US quart remain in the motor after draining. I am not surprised the Honda Canada jug is filled in the USA. Almost all of our oil is exported to the USA for refining. Canada supplies the USA with more than 40% of its crude oil, mostly from the Alberta tar sands. A good arrangement for two friendly countries joined at the hip.
11-10-2017, 04:23 AM
(11-10-2017, 04:06 AM)Nortoon_imp Wrote:(11-09-2017, 07:34 AM)Blockhead_imp Wrote: "Also both bikes call for 4.1 qts when doing an oil change with filter." There are only 9.5 liters in a US quart. So you get 10 top ups and we only get 9 1/2. ![]() Either way, if you want to be able to rely on the sight glass you need the extra 1/10th of a quart, unless the jug is enough. And it may be if 1/10 of a liter or US quart remain in the motor after draining. I am not surprised the Honda Canada jug is filled in the USA. Almost all of our oil is exported to the USA for refining. Canada supplies the USA with more than 40% of its crude oil, mostly from the Alberta tar sands. A good arrangement for two friendly countries joined at the hip.
11-10-2017, 04:28 AM
(11-10-2017, 04:23 AM)Houtman_imp Wrote:(11-10-2017, 04:06 AM)Nortoon_imp Wrote:(11-09-2017, 07:34 AM)Blockhead_imp Wrote: "Also both bikes call for 4.1 qts when doing an oil change with filter." Thanks! Had time to fix it.
« Next Oldest | Next Newest »
| Ticking noise from top part of engine | Kingkong_imp | 40 | 2,911 |
03-18-2021, 01:22 AM Last Post: GoldOxide_imp |
| Engine light Blinking | tory_imp | 25 | 1,956 |
12-04-2019, 10:38 PM Last Post: GoldOxide_imp |
| Location of Engine Number on Engine? | cb1100_dude_imp | 2 | 336 |
05-29-2019, 01:44 PM Last Post: cb1100_dude_imp |
| Engine Sound Changed After Service | EarsOnWheels_imp | 19 | 1,211 |
07-28-2017, 11:07 AM Last Post: PowerDubs_imp |
