Tar spots
(02-18-2019, 11:01 AM)GoldOxide_imp Wrote: Okay, that is just weird funny.
Note: Brake fluid (even the free stuff) can damage surfaces. Recordsol/kerosene etc. can be more forgiving.
Not brake fluid but brake cleaner, two different thingsSmile
Ah ya, my bad.
WD 40, single edge razor blade and 0000 steel wool
(02-18-2019, 12:10 PM)The ferret_imp Wrote: WD 40, single edge razor blade and 0000 steel wool
Sounds exactly right for those "bonded lumps of stain". Thumbs Up
WD-40 is my go-to cleaner too.
I would try mineral spirits, that's always my go to for removing tough things without damage. Used it for years in the flooring industry to remove adhesives including cutback adhesive which is tar based. As always though test it in an obscure spot first.
Mineral spirit is a very good dissolving agent , I use it often when having to get dried silicone of something.
My "go to" cleaner for anything petroleum based is Gojo creme hand cleaner. Mechanics have used this stuff for years to get grease and grime off their hands. It comes in a 28oz. white plastic tub with blue lettering, and contains NO abrasives. There is an orange version that DOES contain abrasives, and is NOT what you want so be aware of the difference between the two.
When the bike is cool, dab some on the spots to be removed and let sit for a few minutes. The Gojo will soften/dissolve the spots and will wipe off with a rag or paper towel. Thick spots may require a little encouragement to break up with a thumb nail. This stuff is also great for removing adhesives left behind from peeling off various stickers on all sorts of things, aside from being a great mechanics hand cleaner. A tub is usually about $4 at auto supply stores. It will not damage paint, clear coat, plastics, chrome, other metals, or your hands. I even use it to de-grease-de tar the rocker panels on our cars periodically.
Looking back through the posts in this thread, one theme appears certain:
Avoid acetone-based products.
I don't see anybody referencing associated products. They will haze and/or peel finished surfaces, as well as melt plastics.
(02-19-2019, 03:57 AM)GoldOxide_imp Wrote: Looking back through the posts in this thread, one theme appears certain:
Acetone is good for removing nail polish.....
  2014 CB1100 - rotational vibration/wobble - flat spots in tires? rozbabbo1100_imp 7 657 08-04-2022, 10:10 AM
Last Post: 1973cb750
  black spots cilinder head bolt cover area - sealing problem or nothing? Riko_imp 11 791 01-13-2016, 10:52 AM
