Muffler Gasket for Arrow Slip-On
(04-22-2019, 11:54 PM)CaptainChris_imp Wrote: Last night I finally received my Arrow silp-on. Went to do the install and it was a fairly straightforward process. Afterwards during my sanity check with the service manual, I noticed that the stock muffler has a gasket (part # 18392-MG7-750) that goes between it and the header. I didn't see this gasket at all while I was removing the stock one, so the Arrow went on without it. How important is this gasket, and is it just for the stock muffler or should any aftermarket one use it as well? After closer inspection on the stock muffler there is something that looks like it could have been a gasket left on the connecting surface, but it doesn't look like it wants to come off and has the feel of a hard plastic.
I believe it is the standard Honda exhaust gasket which Honda seem to use on their systems.
Usually made of a graphite composite which sits under the joint where the clamp fits.
  Knocking noises; vibrations in the handlebar; oil sipping at valve lid gasket TheLegend 47 5,934 11-16-2025, 12:01 PM
Last Post: TheLegend
  Left Side Crankcase Gasket Part number. jbird06_imp 1 337 03-26-2024, 08:56 AM
  Arrow Slip on issue - stock gasket didn’t fit Ddawg1144_imp 4 481 02-21-2023, 07:51 AM
  Clutch slave cylinder gasket Maturecheese_imp 3 401 01-27-2023, 12:33 AM
Last Post: Maturecheese_imp
  going back to stock muffler and other parts Tom_imp 5 430 08-26-2022, 11:12 AM
Last Post: rboe
  Gasket maker peterbaron 16 1,243 05-21-2022, 10:17 AM
  Gasket Pushing out? rdeleon975_imp 13 968 10-22-2021, 02:07 AM
  Clutch cover gasket Streetbiker_imp 2 780 08-20-2020, 07:26 PM
  "13 muffler guard HBFL_imp 2 330 04-16-2019, 08:06 AM
  Slip-on before first service? MinkeyChief_imp 7 554 08-12-2018, 05:55 AM
