Won’t start?
(08-01-2019, 12:04 PM)Retsel_imp Wrote: You could always "jump start" to eliminate the battery issue!
Indeed - that would be instant gratification.
Good grief I think you have to have tiny hands to get that battery out. My big hands can barely fit in the compartment
There is supposed to be a strap around the battery so you can lift it out easily. If it's not there, check the bottom of the battery tray when you get it out.
Sent from my Nexus 5X using Tapatalk
My batteries did not have straps but I put them on when I replaced a batterie.
Definitely did not have a strap! I went to the local batteries plus and they wanted $126 for a dang battery. I found one on amazon for 40 bucks so hopefully it comes in soon.
my battery has a strap.
Honda Service Bulletin says for mechanics to leave it in there when prepping the bike
[Image: 0bbfa1e3ea1f8d614737ce546d89d617.jpg]
You can even get one of those straps from Honda! https://www.partsfish.com/oemparts/a/hon...64/battery
Item 10
Looking at the dealer prep instructions ,I wonder if my bike didn’t come with a battery strap, did they read to remove protective coating from the exhaust ? I think not.
Just to be sure, you mention " the kill switch is off ";
It needs to be " on" ( pushed down towards you ) for the bike to start, if it is rocked away from you ( off ) the engine will not start but the lights will dim whilst the starter button is pushed but nothing happens.
The green neutral light must also be on unless the clutch lever is pulled in in order to start.
My battery has the strap. That no-name $40 Amazon battery should be just fine. That's what I use in all my bikes and they work great and last for years.
  High engine revs on start up CBX1000_imp 21 1,734 06-06-2024, 02:40 AM
  CEL after Jump Start rage91_imp 23 1,499 04-14-2023, 01:25 AM
  Won't start RLS_imp 5 435 05-12-2022, 05:58 AM
Last Post: RLS_imp
  CB 1100 won't start GeorgiaRider_imp 30 1,955 12-19-2020, 11:19 PM
  Low rattle on cold start. shahyaan_imp 22 1,484 11-30-2020, 12:01 AM
  Bike crank but wouldn't start. zirconxi_imp 67 3,793 04-25-2020, 01:37 AM
Last Post: White Dog_imp
  strange start pdedse 48 2,564 02-02-2020, 06:34 AM
  2014 Start - Cutoff Switch Question deltamark 16 1,243 04-18-2019, 06:23 PM
Last Post: flynrider
  Motorcycle doesn't start, high oil temperature indicator comes on Saarang_imp 17 1,149 07-20-2018, 07:14 AM
Last Post: SportsterDoc
  No start - Battery replaced - No start jerrycon_imp 20 1,356 07-16-2018, 01:28 PM
