Threads: 115
(10-17-2019, 09:39 PM)GoldOxide_imp Wrote: I've read that some prefer bias ply (BP) for spirited use (e.g. racing), but radials better support the weight of touring. For regular street use, I cannot tell the difference. I do know that statistically for me, my BP tires seems to take on screws and nails significantly more often than radial. However, maybe that was an unusual string of poor riding luck. I would nail that down as being screwed.
(10-18-2019, 12:03 AM)Houtman_imp Wrote: (10-17-2019, 09:39 PM)GoldOxide_imp Wrote: I've read that some prefer bias ply (BP) for spirited use (e.g. racing), but radials better support the weight of touring. For regular street use, I cannot tell the difference. I do know that statistically for me, my BP tires seems to take on screws and nails significantly more often than radial. However, maybe that was an unusual string of poor riding luck. I would nail that down as being screwed. I would nail that down as being screwed.
Ha, ha ... you nailed it!
Threads: 245
Likes Received: 1,154 in 493 posts
Likes Given: 940
What Rocky said. I've got Avon 26s on my spoke Bonneville, and I can't say that they're any better or worse or different, for that matter, than the radials on my CB.
Threads: 347
Likes Received: 853 in 470 posts
Likes Given: 985
(10-17-2019, 01:01 AM)m in sc_imp Wrote: i run avon am26's on my 99 concours, love em. they are very grippy, will prob go the same way on the cb when the time comes.
this lays out the differences pretty well.
https://www.revzilla.com/common-tread/wh...dial-tires
There’s a dispute here! Revzilla says the opposite, GO.
Threads: 39
(10-17-2019, 01:36 PM)zirconxi_imp Wrote: (10-16-2019, 11:08 PM)bigsheep_imp Wrote: (10-16-2019, 07:31 PM)zirconxi_imp Wrote: I have used Bias-Ply before. the tyre is quite heavy, last longer compare to my current T30. But performance and wet grip wise T30 still better.
T30 discontinued right or is it only available in 160/60?
Bridgestone T30 had been replaced by T31. I am going to change mine to T31 this month end. Personally i felt radial will be better in absorbing corner bumps. Bias-Ply will bump around quite often compare to Radial and can't take corner aggressively... And BiasPly make my CB felt like riding a Harley.
I have the Avon's on both my Bonnie and CB. They grip well, are predictable (for me anyway), and handle aggressive cornering very well. Highly recommended.
(10-18-2019, 07:50 AM)Cormanus_imp Wrote: (10-17-2019, 01:01 AM)m in sc_imp Wrote: i run avon am26's on my 99 concours, love em. they are very grippy, will prob go the same way on the cb when the time comes.
Sure. I personally can't confirm either way.
Threads: 347
Likes Given: 985
Nor can I. Nor would I be likely to know the difference if I rode them both.
(10-18-2019, 10:29 PM)Cormanus_imp Wrote: Nor can I. Nor would I be likely to know the difference if I rode them both.
Probably what is funny is that if someone told me with reason that "this" was better than "that", and then I rode them both, I would not detect a meaningful difference.
However, I cannot recall ever getting a flat with radials.
Threads: 115
Motor cycle racing went to radials decades ago for better handling.
Likes Received: 579 in 316 posts
Likes Given: 971
(10-19-2019, 03:27 AM)Houtman_imp Wrote: Motor cycle racing went to radials decades ago for better handling.
^^ +1
