Linked Brakes
Just so you know, Ferret’s rear master cylinder did not lock up his rear brake. The Secondary Master Cylinder (SMC) mounted on the left front fork did the deed.
(12-10-2019, 12:07 PM)LongRanger_imp Wrote: I'll pile on too. My RT has linked brakes using the front brake lever, but allows rear brake activation by using only the brake pedal. Like Gone in 60 and the ferret, I don't even notice.
That's interesting. Applying some rear when using the front is good practice. Being able to use the rear only, is sometimes a must.
If linked brakes systems can do this, then I think is something good to have.
However, as you lose some ability to independently modulate the brakes, I think linked brakes should be only installed with ABS.
PS: I saw the VFR linked brakes system once, and it was interesting that the braking pressure sent to the rear was proportional to the braking torque reacted on the front callipers mounting, and not directly proportional to the force on the front brake lever. This is a good way of making sure that the system will never "lock the rear first", even if you have oil on your front disks!
  Front Brakes ain't what they used to be misterprofessionality 11 1,356 05-09-2025, 09:10 PM
Last Post: Whoops
  Bleeding brakes with ABS j3gq_imp 31 2,208 12-22-2021, 08:31 AM
  Small quiz; brakes are dragging. max 31 2,197 11-29-2021, 12:20 PM
  2014 CB 1100 Front Brakes troubleshooting mustang462002_imp 23 3,085 11-17-2021, 06:53 AM
Last Post: max
  Bleeding brakes (CB1100A non-ABS) tod.branko_imp 5 528 09-20-2021, 07:43 AM
  2014 CB1100 Deluxe No front brakes Roger the shrubber_imp 16 1,032 08-05-2021, 02:01 AM
  brakes simulating T.Rex j3gq_imp 8 772 10-12-2020, 02:49 AM
  Rear brakes... what I did wrong and where to go now? Inhouse Bob 32 2,254 07-11-2020, 01:37 AM
  Brakes! Captainwoot_imp 19 1,370 08-22-2019, 08:51 AM
Last Post: Captainwoot_imp
  Squealing Front Brakes Just Before Complete Stop CARUZIN_imp 47 4,077 03-03-2019, 05:22 PM
