Battery replacement - Beware aftermarket
I have good luck with East Penn aka Deka batteries
FWIW I've been using Yuasa batteries for 25 years and have always had good service and longevity from them.
It's not uncommon for me to get 6-7-8 years out of them.
The longevity could possibly be related to the fact that we don't get super high temperatures up here (which is deadly on batteries) and the batteries are in storage over our long winter - November to April for me.
My OEM made it 5 years FWIW. No battery tender, not since I've owned it at least. Replaced with another OEM (which I got for like $130 on Rocky Mountain I believe).
(10-04-2018, 01:55 AM)misterprofessionality_imp Wrote:
(10-03-2018, 10:29 PM)Roper_imp Wrote: I replaced my battery last year with a much lighter lithium ion battery. No worries so far.
which one specifically, and what was the weight savings? (i'm sorry if you made a thread about it).
Without going and pulling it out to look for the exact model number: It was a Fire Power featherweight lithium ion. Length and width was the same as OEM, but it wasn't as tall. Cables still attached but one was a little tight, IIRC. I think the weight was about 2.5 lbs, and the Yuasa is 8.6 lbs. I got mine through Rocky Mountain ATV/MC. The right battery will come up in your search if you put in year, make, and model. I remember it being about $120.
See this thread about Flynrider's (positive) experience with a lithium battery http://cb1100forum.com/forum/showthread.php?tid=5457
You could always put some foam underneath the batterie if not tall enough.
I guess my point here is that the OEM battery likely has more lead plates which makes it theoretically better. The lighter (not the lithium-ion) batteries may fit and work under most conditions, but they have not been time tested.
BatteryStuff.com outstanding company out of Grants Pass, OR
Been buying batteries from them for over 10 years and they provide a great product and service. Bought a lot of batteries from them because down in AZ you're lucky to get 3 years out of ANY battery due to the heat. I usually go for their mid-priced option, as according to them it's comes off the YUSA product line, and is made in Japan vs. China.
My original battery finally quit on me earlier this year (after 5 years). I can't even recall what brand I replaced it with, but I do recall that like the battery pekingduck purchased, the cold cranking amps were rated much lower than the OEM Yuasa unit. However, the local independent battery supplier where I bought the replacement battery said that you can't always go by the manufacturers ratings. They tested the replacement I bought at over 200 CCAs. Only time will tell how things will work out.
(10-07-2018, 02:13 AM)Interceptor Pilot_imp Wrote: BatteryStuff.com outstanding company out of Grants Pass, OR
Unless I missed it, they don’t list a battery for the CB1100.
  ABS , speedometer and battery Walter 10 802 05-02-2026, 01:29 AM
Last Post: Walter
  Yuasa Battery Life dave 28 2,584 04-01-2026, 04:44 AM
  CB1300 headlight bucket replacement spechg 5 381 03-16-2026, 10:12 AM
  HISS Key replacement UK Davidjill_imp 12 993 01-19-2026, 05:09 AM
  Rear brake pad replacement LongRanger_imp 39 3,613 05-03-2025, 10:45 AM
Last Post: Delphisa
  Rattle on right side exhaust / battery CB1100i_imp 4 685 04-18-2025, 02:48 AM
Last Post: CB1100i_imp
  New speed meter replacement ACE_IRA_imp 3 523 02-13-2025, 06:25 AM
  Battery jumper the Ferret 14 1,107 10-28-2024, 10:58 PM
  CB1100 SA-E 2017 Battery Davidjill_imp 1 290 08-01-2024, 02:33 AM
  wonder battery The Gecko_imp 58 4,653 02-19-2024, 11:20 PM
