Best "Net Gain" CB11 Exhaust Option
I'm really sorry that you find my honestly-held opinion "insulting, inflammatory and ultimately IGNORANT". Not a lot of room for discussion or dissent there, is there, so I won't bother?
On a nice, friendly forum like this, I will refrain from expressing my view on your response - suffice to say that I think that you are wrong on almost every point you try to make.
If there is an 'attitude' here that needs changing, it us yours, my friend. I take it that you don't handle contrary opinion very well?
We're all free to treat our 'bikes the way we believe is correct, and contrary opinion is just that, not any kind of insult, or ignorance.
I shall say no more out of respect for those running this great Forum.
[Image: 6d95517fdfd5cacb525832c90204264f.jpg]
ok, lets take a step back and take a breath everyone.
All opinions have value, and merit. We can disagree without becoming disagreeable, especially without resorting to derogatory name calling and insults.
I'm not sure a world wide public forum is the best place to ask a question, especially if you only expect those that agree with you to respond. Usually doesn't happen like that.
If you can't get a long I'll use moderators digression and delete the thread.
Thumbs Up
(07-13-2020, 04:14 PM)E11even_Hunnit_imp Wrote:
(07-13-2020, 02:22 PM)PowerDubs_imp Wrote:
(07-11-2020, 06:05 PM)Bazbro_imp Wrote: So... you're looking for 'performance', eh?
Why not just buy a performance 'bike? Then leave the CB as the beautifully-running 'retro' bike it is, with no pretensions of 'performance' (120mph not fast enough?), and enjoy the stock way that it runs. Reliability allied to a nice torquey motor - why ruin that?
I don't get why loads of you guys buy THIS 'bike and then just want "more power", totally ruining the WAY this CB delivers the type of power it does.
TORQUE... not power is the name of this game.
Each to his own, I suppose.
Mind you, the bland looks of the CB is crying out for "something" to be done to liven it up! Four exhausts would do that, a la CB750.. Thumbs Up
I find posts like this insulting, inflammatory, and most importantly- IGNORANT.
My bike makes more power, MORE TORQUE at every rpm, than stock.
It also rides smoother, more comfortable, and is awesomely cool to look at.
I wanted a classic UJM, I don’t want a sport bike. I also wanted more snot, and I’ve got it.
Your engine performance, and your attitude need improving.
I made - to the wheel - 100HP, 72.5TQ on stock ECU- so piggyback fueling, no IGN changes.
I have since added a Guhls ECU tune- need to get her back to the dyno and see what I’ve gained.
https://youtu.be/l-JUu8JBjGc
[Image: 9d650aeba09edb1ecf40ff8b5844fc21.jpg]
[Image: 6f7dae476fcae6d2a92588945014be0c.jpg]
The man himself has spoken. Thanks for chiming in, Josh Beer
That last Dyno pull nearly got me in the mood Tongue
What exhaust are you running? I'm in a situation where basically I get to choose between either a Staintune slip-on or a Moriwaki 4-1 system(1 piece version, looks nearly identical to the Yoshi?)
Leaning towards the full Moriwaki for obvious reasons, unless you have reason to believe the Staintune with the stock headers should be the way to go, power-wise
Exhaust aside, I've been debating how or in what order I should approach the aforementioned complementary mods. Do you recommend I wire up the PCV prior to getting the ECU flash?
Also very much looking forward to seeing the results of your next Dyno run, whenever that may be Thumbs Up
I am running arrow headers and a staintune muffler.
Runs great, sounds great, look great.
I would happily run a Moriwaki 4-4 though as those look and probably sound wonderful.
I think any exhaust that ditches the cat and more open muffler should see roughly the same power gains. Technically a 4-1 is considered most efficient as far as pulses- but I think a lot of that is old school data from many decades ago.
Naturally as engine displacement gets larger, eventually dual exhaust is required.
4-1 eases any discrepancy on cyl tuning- but if you are tuning for power, not lean cruise economy- it shouldn't matter. DJ does have dual sensor kits I briefly seen somewhere- not sure if they have one for the DLX, or if it was just for big cruisers like a harley.
On tuning- an ECU flash is locking you to some other guys settings on the day and location that tune was written. Better than nothing? Sure... but if you are already spending considerable money on a full exhaust...why skimp on feeding the engine?
Flash ECU- good, but locked, and not locked for YOUR bike, in YOUR riding altitude and weather.
PCV- just does fuel, and honestly if you look at the supplied 'maps'- they just throw 13.2 at the table...and the 2 trim files they show are different than each other...for no real reason than 2 different bikes on2 different days made them. Neither will 100% match your bike.
To me, the best answer is an ECU flash so you get an ign remap, the lower gear reductions removed, higher redline, higher top speed- AND both the PCV and Auto-tune box.
The addition of the auto-tune box will let YOU pick what fuel you want at what RPM and throttle position you want...and will adjust to that on the fly while you ride- regardless of temperature, altitude, humidity, etc..
I haven't tested it yet- but Popgun figured out a speed sensor wire on the bike- and the Dynojet setup has the capability to have different fuel maps for each gear...as load does change how the engine requires mixture ideally- and you can map say 6th gear just to get great MPG on a long trip.
Yea, I know- ECU flash + both DJ boxes, and you will probably need a new O2 bung welded into whatever header you chose- is a lot of cabbage- but it is worth it. And it is fun to play with. Smile
This a Big CC turbo kit on a stock engined Z900RS no loss of bottom end powerr. I think the compression ratio on the CB110 is perfect for a turbo. This would knock the spots off a set of cams fancy exhaust etc and probably not cost much more..CoolCool
(07-14-2020, 05:59 PM)Brad14_imp Wrote: This a Big CC turbo kit on a stock engined Z900RS no loss of bottom end powerr. I think the compression ratio on the CB110 is perfect for a turbo. This would knock the spots off a set of cams fancy exhaust etc and probably not cost much more..CoolCool
Would love to see you try it and get back to us with your findings Thumbs Up
I ended up picking up a 1-Piece Moriwaki 4-1. Will be installing it tomorrow along with fresh new rubber(Angel GT's) SW Motech guards and a few other goodies.
Unfortunately, I jumped the gun and purchased the wrong PCV, so, proper tuning of the bike, is going to have to wait a little Sleepy
I read this post through and thought about it for a bit...
First off I love my 2014 CB1100. It is am amazing bike and i just got back from my favorite run this afternoon. Just a pleasure to ride.
But... I am the type that needs to make the bike my own. The very first thing I did was add the full Yoshimura Exhaust System. Why did I choose this one? It was strictly for looks! I loved the vintage 4 cylinder air cooled bikes with the Yoshimura type 4 into 1 pipe. I always said I would get a bike just to add that exhaust too. I was looking for the CB350 to do this too! But the CB1100 was the prefect bike for this type pipe and the perfect addition to my Keeper Bike List.
I then added more goodies like the TSR Air Filter housing, K&N Air Filter and TSR Intake Funnels. I did have the CPU reprogramed. The bike is amazing. I just love it even more. I rarely ever use this new found power but it is sure fun to play with after a long hard day.
So best exhaust? I do not think you will see the difference between one high end pipe and another unless you ride the redline. For the easy going people like me, go with the one you like the looks of the best and have a ball! I am.
Got the exhaust installed- I absolutely LOVE the new sound, the bike demands it's well deserved attention.
[Image: 7c4d8534e5d6f0795107b7246ac82c21.jpg]
Ofcourse improper fuel management causes for some pockets and inconsistencies along the powerband along with backfiring(more like popping) during deceleration, the latter I don't mind as much, but this will have to do for now. PCV + Guhls alone will run me $700 without counting the DJ autotune box. Certainly looking forward to it though
  18" Tubed Tyres UK Davidjill_imp 2 377 07-24-2024, 10:12 PM
  Front ABS Brake"Rain Stick" noise bflint 3 457 07-12-2024, 08:36 AM
Last Post: Race_ca1
  Delkevic 9" Oval Install Problems. jbird06_imp 4 460 06-11-2024, 08:25 AM
Last Post: devildogdoc_imp
  2017 EX "Rim width Sizes" 17-CB-002 2 334 04-05-2022, 03:21 AM
Last Post: 17-CB-002
  Do your gears "clunk" while downshifting? rjk555_imp 65 4,798 07-10-2021, 02:08 AM
  Rear Brake "clunk" iogear99_imp 3 352 04-25-2020, 01:47 PM
  chain lube.. "fluid film" Chuckk_imp 14 994 11-19-2019, 12:57 PM
  "13 muffler guard HBFL_imp 2 314 04-16-2019, 08:06 AM
  "click click" noise when rear wheel spins jtopiso_imp 9 674 08-21-2018, 07:48 AM
  Tire replacement - Not a "Tire Thread" SportsterDoc 12 951 07-18-2018, 06:50 AM
Last Post: SportsterDoc
