Low rattle on cold start.
(11-10-2020, 03:43 AM)GoldOxide_imp Wrote:
(11-10-2020, 03:41 AM)shahyaan_imp Wrote: Actually now I read it in detail. It could be oil as well. Oil is a bit old from previous owner not using it much. I was planing on doing a quick oil change.
I’ll have to decide on the ideal choice for this bike. At the risk of starting another oil debate may go semi synth within the temperature range for my location.
I always used 10W40, and initially Honda GN4. I changed to semi and then full synthetic and the engine was quieter and clutch [even more] buttery.
(I think the statement covers much of the oil genre.)
That’s perfect. I like making a choice based on experience with. I’ll grab the oil as it’s needed and cheap.
I've just gone with the recommended GN4 10W-30 the entire time as it's often chilly on my rides. The shifting is very smooth and silent.
My bike has now done over 130,000 kms. I now find that, as the engine gets hotter, the gearbox gets stiffer. It shifts fine when under way, but finding first and neutral is tough at a standstill or low revs.
(11-11-2020, 09:56 AM)Cormanus_imp Wrote: My bike has now done over 130,000 kms. I now find that, as the engine gets hotter, the gearbox gets stiffer. It shifts fine when under way, but finding first and neutral is tough at a standstill or low revs.
Makes the bike harder to steal when you leave it running. Smile
hadn't thought of that, GO. I should've been clearer: it's hard to get the bike out of 1st or 2nd and into neutral when it's hot. Goes in all right.
(11-11-2020, 04:26 PM)Cormanus_imp Wrote: hadn't thought of that, GO. I should've been clearer: it's hard to get the bike out of 1st or 2nd and into neutral when it's hot. Goes in all right.
Ah, okay. An annoying ownership distraction then, but partially tempered by the 130000+ kms of love.
I can’t seem to get the GN4 oil here in the UK. Any preference with Castrol or Motul?
I've nearly always used Castrol, it's easy to get hold of (Halfords for a start) and is a quality brand. If you Google reviews there's so many owners that use it and I couldn't find any negatives last time I researched it. Put it this way I will be using it again in my CB.
I have always used the Mobil 1 synthetic motorcycle oils in my bikes , is this available in the UK ?
(11-29-2020, 10:49 PM)Jfro5687_imp Wrote: I've nearly always used Castrol, it's easy to get hold of (Halfords for a start) and is a quality brand. If you Google reviews there's so many owners that use it and I couldn't find any negatives last time I researched it. Put it this way I will be using it again in my CB.
That’s what I was hoping. Euro Carparts doing 50% off the motorcycle fully synth version.
(11-29-2020, 10:51 PM)Houtman_imp Wrote: I have always used the Mobil 1 synthetic motorcycle oils in my bikes , is this available in the UK ?
I think Mobil 1 is available. Though didn’t see it in my searches when filtering for CB requirements.
  Rattle on right side exhaust / battery CB1100i_imp 4 659 04-18-2025, 02:48 AM
Last Post: CB1100i_imp
  High engine revs on start up CBX1000_imp 21 1,752 06-06-2024, 02:40 AM
  2017 tail light rattle Venteuri_imp 2 372 05-14-2024, 05:55 AM
Last Post: Venteuri_imp
  CEL after Jump Start rage91_imp 23 1,518 04-14-2023, 01:25 AM
  Won't start RLS_imp 5 439 05-12-2022, 05:58 AM
Last Post: RLS_imp
  Rattle-can Magic Phadreus_imp 4 365 08-30-2021, 04:35 AM
  CB 1100 won't start GeorgiaRider_imp 30 1,968 12-19-2020, 11:19 PM
  Rattle when going over bumps. cheddarcheese_imp 15 1,051 06-15-2020, 12:00 AM
  Cam chain rattles when cold Speed_imp 24 1,525 05-28-2020, 05:41 AM
  Bike crank but wouldn't start. zirconxi_imp 67 3,861 04-25-2020, 01:37 AM
Last Post: White Dog_imp
