 Ticking / clicking sound after oil change
(02-02-2021, 02:21 AM)Lord Popgun_imp Wrote: Since it seems speed related and not RPM, is it possible that the rear wheel is out of alignment and you are hearing the chain? IIRC we had a member have a chain click due to that. Wheel being cocked and chain made the noise as it went around the sprocket.
Clap Clap Clap Clap Clap Clap Clap Clap Clap Clap Clap Clap Clap
Your brief and very succinct sentence turned out to be masterful, Lord Popgun.
The main noise is coming from the chain like you expected. The volume increases with speed (while on centre stand)- so 5th gear tick-over is the worst. There is also a lessor clicking noise coming from the cam shaft cover area (again, volume related to speed) - I suspect that this second, lessor noise is related to the cam chain sound that the garage claimed. It might be that this second sound was there already when I took the bike in. I may get the cam chain replaced if it gets worse.
So, I will take my spanner down there a bit later and hope for the best - the ultimate easy solution, beaten only by the "has it got any gas in it?" answer. My favourite type af answer. Thanks guys.
Worship
Another possibility to consider is the heavier weight oil that was previously in the motor had some damping effect on the normal noises this motor makes. There are sources of small clicking sounds even when everything is in tune. Going with 10W-40 is the right call, though, for a hot climate.
You did mention that the noise goes with wheel speed. In a given gear, that would also mean it's going with engine speed.
Do a test... Go somewhere without a lot of traffic, get rolling along and then pull in the clutch and close the throttle. If the noise keeps up, it's something in the transmission, chain, or rear wheel. If the noise goes away, it's in the engine somewhere.
When the forum first started in 2013 there was a lot of discussion about a clicking ticking noise, hear primarily after shifting into second gear and accelerating which we determined to be fuel injectors ticking. Hasn't been any discussion of it in recent years that I recall.
Guth posted this in May 2013, a month after the forum started:
"I've noticed a noise on my bike that I thought could be the valves. It can be heard as a clicking that occurs just as you begin to twist the throttle. After some research, I've come to attribute this to the fuel injection system. This is the first fuel injected bike that I've ridden and I have to admit to not being familiar with such things."
later many came to the same conclusion
another clicking noise was determined to be a dry chain
  Engine clicking/ticking metallic noise! WTF? Tortuga_imp 28 2,053 10-11-2024, 04:53 AM
  Sound check what wrong tory_imp 3 399 03-30-2022, 12:33 AM
Last Post: 1973cb750
  tire change Tom_imp 7 664 05-31-2021, 11:37 PM
Last Post: Tom_imp
  Best Honda CB1100 Exhaust Sound RS EX? charles2021_imp 1 251 05-27-2021, 09:47 AM
Last Post: bioman_imp
   Ticking noise from top part of engine Kingkong_imp 40 2,572 03-18-2021, 01:22 AM
  First oil change for this heathen koehlerk_imp 67 4,226 02-20-2021, 02:42 PM
  Odd Throttle Clicking When Accelerating or Decelerating codyp1814_imp 7 684 01-29-2021, 01:04 AM
Last Post: supruet_imp
   front suspension oil change CB1100 EX 2015 (23700 kms). recommendations ?. Alfgaxatico_imp 7 608 11-23-2020, 07:34 AM
Last Post: Alfgaxatico_imp
  Chain making clanking grinding sound. bflint 36 2,492 11-09-2020, 05:04 AM
Last Post: LakeWylieJoe_imp
  Oil Change interest? Scotty_imp 10 798 09-15-2020, 09:40 PM
