CB1100RS static sag
How can a torque wrench check pressure? Tongue
I usually put 2psi more that Honda spec and the bike seems to handle a lot better. YMMV.
I use a Motion Pro digital gauge, probably like Houtman’s. I hope it’s accurate.
(03-22-2021, 09:47 PM)Jfro5687_imp Wrote: Just out of interest Olof what tyre pressures are you running?
I aim to set mine at factory 36/42 cold however I have discovered this morning (when checking my car tyre pressures) that the two pencil type gauges I use at home actually give a 2 psi reading difference! I checked all the wheels on my car and then my wife’s, every tyre exactly 2psi different. They are decent ones so that did surprise me TBH.
Now I’m pretty sure that would make a difference on a bike and because I know which gauge I’ve used on the CB I’ve realised I’ve possibly been running 34/40 in reality. I put 2psi extra in both front & rear and will see if I can feel any difference next time I go out. I’m making an assumption of course on the more accurate reading being the one I’ve gone for (based on the old dig your thumb into the sidewall test).
Anyone else found a noticeable difference running off spec either intentionally or by accident like me?
I have not had my CB long enough to comment on the tyre pressures and how they feel on that but my Tiger 1200 is very sensitive to pressure on the front, a difference of just a few PSI has quite an impact, the front end gets quite vague on losing a few.
(03-23-2021, 05:33 AM)Lord Popgun_imp Wrote: How can a torque wrench check pressure? Tongue
Lol torque wrenches like air pressure gauges can be accurate or not, and need to be calibrated periodically. I've had mine for maybe 15 years and have never had it calibrated, but then again I dont put engines together. It's probably close enough for an axle nut, but not much more technical that that at this point. I dont think I'd trust it for an oil drain bolt lol
I check my clicker torque wrench with a beam torque wrench as the latter stays more the same and I do not use the beam one much at all.
I understood what you meant Ferret. Just funning with ya Big Grin
As with many gauges, I try to get a "consensus" between multiple devices. Sure: It ain't certified, but surprisingly I often get very acceptable variance (many times zero) that "feels good enough".
Thanks for the feedback chaps. It just crossed my mind reading Olof’s thread that before we dive into altering suspension maybe we ought to check our tyre pressures first, just in case the cause of whatever it is we think needs addressing is an easy fix right there under our noses.
(03-23-2021, 05:04 PM)Jfro5687_imp Wrote: Thanks for the feedback chaps. It just crossed my mind reading Olof’s thread that before we dive into altering suspension maybe we ought to check our tyre pressures first, just in case the cause of whatever it is we think needs addressing is an easy fix right there under our noses.
Good point. I agree that when tinkering with setup it's good to only change one parameter between tests, and try to keep other - such as tyre pressure - as similar as possible. I never mentioned it since I have a morning routine since way back (from when I rode cheap wrecks leaking everywhere) to check oil level and tyre pressure, but in this I'm quite alone among my riding friends. Most seem to check monthly or less, typically at the gas station where they happen to be when the thought strikes them. No criticism, each have their own standards. These guys are fine on their bikes, never had a problem and happily label me as OCD. Big Grin
  O2 sensor eliminator not working on CB1100rs 2017 tory_imp 33 3,043 03-06-2026, 04:31 AM
  CB1100RS fuel tank rust Narciso 12 1,431 09-27-2025, 02:06 PM
Last Post: tdbru
  Suspension Static Sag ozigoo 27 1,967 05-12-2021, 02:05 AM
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 437 04-03-2021, 01:35 AM
  2017 CB1100RS Front Fork Teardown CotswoldPhoto_imp 4 441 01-29-2019, 04:24 AM
Last Post: the lodger_imp
  Adjust low beam on CB1100RS Ban_imp 3 352 02-11-2018, 06:29 PM
Last Post: Ban_imp
