Neutral safety problem-
Figured it out! I had ben focusing on the pin connectors behind the cover also. I download the manual to find the location of the sensor close to the exhaust- aha! There is a small connector that popped off and pulled back in the bundle when I was monkeying with the wires.
Next question: why is it when you figure out a simple glitch like this you feel like a superhero???
THANK YOU ALL!!!
(06-05-2021, 04:08 AM)boatdetective_imp Wrote: Hey there. So I removed my headers to polish them up. Unplugged some wires for more access. Reinstalled and tidied up wires. Bike runs fine- but the green N light does not go on when the bike is shifted into neutral. Also, when the bike is in neutral and you put down the kickstand, the engine shuts off.
So- there's some neutral indicating circuit that is open. Anyone know where these wires/switches are in the harness? The wiring is tucked away very cleverly so any help would be greatly appreciated.
The bike shutting off with the kickstand down is a safety figure so you do not do a kickstand side-wheelie. Old bikes did not have this, I saw a few crashes years ago when a rider would take off with it down.
Lovely, we appreciate the update and fix, having a diagram can be a big step forward and welcome to the world of "fixed it highs" feelgood after learning a new trick.
And things like this happen regularly, i failed to start my new cb1000r, lights but no start, it went a lot better when i got it out of gear and the green neutral light came on....ROFLROFL
Safeties work, i would have been very sad if the bike took off in gear if it wasn't for the little neutral switch, unusually i had stopped the engine with the killswitch in gear and forgotten about it.
There is No substitute for experience and much cheaper to learn from someone else's mistakes as long as you are not standing in front of it.
(06-05-2021, 12:51 PM)boatdetective_imp Wrote: Figured it out! I had ben focusing on the pin connectors behind the cover also. I download the manual to find the location of the sensor close to the exhaust- aha! There is a small connector that popped off and pulled back in the bundle when I was monkeying with the wires.
THANK YOU ALL!!!
Better to feel like a Hero than feeling like an idiot for messing something up in the first place.....
Thank you for letting us know what you found. Good work!
Very nice to read boatdetective. Congratulations. Happy riding!
  CB1100 Idle speed instability problem ericlo69_imp 1,434 118,970 07-26-2026, 01:51 AM
  idle problem update 1973cb750 37 2,141 05-12-2026, 08:38 PM
Last Post: rdprdp01
  Chain or sprocket problem ? The Gecko_imp 14 1,271 07-30-2024, 10:05 AM
  O ring chain problem Mixagon_imp 7 665 10-17-2023, 07:28 AM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 4,857 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
  May have a problem the Ferret 12 858 01-20-2023, 04:53 PM
Last Post: max
   2017 EX Headlight Dimmer Switch problem? sleeper_imp 24 1,900 10-08-2022, 12:27 PM
  Fast Idle Problem Solved Nachodaddy 17 1,516 10-08-2022, 09:18 AM
  Another High Idle Problem emptysea 60 4,074 07-05-2022, 11:41 AM
  Tail light install problem iamheero_imp 9 729 11-27-2021, 02:58 AM
Last Post: Bazbro_imp
