 Actual Oil Capacity of the CB1100???
My experience is that owners manuals often list the oil amount for changing as a little too much, maybe because some oil remains or whatever. And some bikes don't like their oil level above 1/2 way up the glass or dipstick, or it blows into the airbox.
When I changed the oil and filter in mine a couple months ago (it was the first time), after letting it drain for almost an hour I installed the drain plug (just finger tight) and leaned the bike over to the right for a minute or two, then back on the stand. When I pulled the plug again probably 6 ounces more came out.
I added 3 qts then slowly added from the 4th qt while watching the glass and at 1/2 of that qt the level was about 3/4 up the glass so perfect at that point, but the filter probably wasn't filled. After letting it idle for a minute then settle for another minute the level had dropped slightly to 1/2 on the glass so still good, but I added 1/2 of the remaining half qt which took it to just under the top of the glass. So 3 3/4 qt after a pretty complete drain and new filter is what mine took.
Bike had a fresh oil change when I got it, so probably will not change until late summer. The one bugaboo on this bike is the oil level window...difficult for me to see that tiny window. Wonder if there's a way to fashion some type of dipstick...?
... Honda has been bringing back the dipstick in some newer models, so maybe design sentiment is changing?
(05-19-2022, 01:33 PM)Ollie_imp Wrote: My experience is that owners manuals often list the oil amount for changing as a little too much, maybe because some oil remains or whatever. And some bikes don't like their oil level above 1/2 way up the glass or dipstick, or it blows into the airbox.
This is great information and jibes with my experience. Thanks for posting!
(05-19-2022, 07:47 PM)Wagonpeddler_imp Wrote: Bike had a fresh oil change when I got it, so probably will not change until late summer. The one bugaboo on this bike is the oil level window...difficult for me to see that tiny window. Wonder if there's a way to fashion some type of dipstick...?
Agreed that a dipstick is easier to read. I don't think a dipstick would work because there are metal parts inside the crank case that inhibit the ability of anything to pass straight into the oil... I discovered this trying to remove the excess oil with a straw!
No kidding! Most of the time, I actually have to lie down on the floor to look at mine and I need a strong flashlight to see it when my bike is in the garage. I am sure if I looked at it outside my neighbors would call an ambulance thinking I'd fallen down again.
Might try sticking a light into the filler cap.
(05-20-2022, 08:31 PM)Wagonpeddler_imp Wrote: Might try sticking a light into the filler cap.
Thumbs Up
Great idea Birthday Boy!
Every oil change I did with my 2013 took exactly 4 qts of Shell Rotella T6 synthetic 5W-40 and a new Honda filter. Valves were always good and transmission shifted smoother with the change to Rotella from Honda oil I used at initial oil change.
(05-21-2022, 01:18 AM)redbirds_imp Wrote: Every oil change I did with my 2013 took exactly 4 qts of Shell Rotella T6 synthetic 5W-40 and a new Honda filter. Valves were always good and transmission shifted smoother with the change to Rotella from Honda oil I used at initial oil change.
I also found the CB liked the 5W40 Rotella T6 too. Never an issue, gearbox loved it.
I hate the sight glass and shining a light in the fill cap does not help.
   Rotella T5 10w30 + CB1100 = HAPPY!!! Yata-Garasu_imp 73 6,974 07-12-2023, 01:00 PM
  FORK FLUID CAPACITY Enzofour_imp 6 562 01-29-2021, 06:19 AM
   front suspension oil change CB1100 EX 2015 (23700 kms). recommendations ?. Alfgaxatico_imp 7 666 11-23-2020, 07:34 AM
Last Post: Alfgaxatico_imp
  2017 CB1100 EX FUEL CAPACITY Nortoon_imp 57 3,869 12-09-2019, 01:03 PM
  The actual required services by mileage Streetshark07_imp 5 477 06-29-2019, 07:58 AM
Last Post: SportsterDoc
  Engine oil capacity emullick_imp 1 228 01-03-2018, 10:45 AM
