May have a problem
ROFL true, true
(01-20-2023, 10:11 AM)Lord Popgun_imp Wrote: Sounds about right. Maybe a good cleaning will take care of it. The switch. Cause we know the bike ain’t getting a cleaning!!! Big Grin
ROFL
All makes sense, guess you did not notice the fuelpump wining up during the bump start....
All the red switch does normally is switch the " run " relay and the " start " relay when the engine is started, they are both small relays under the seat.
Because of the low current draw we tend to call this a dry contact as opposed to a wet contact which carries more current and bites through corrosion a bit easier.
This diagram may help to explain what we mean;
Combination of moisture and fine dust, a bit of exercise would clear it out as you have done Ferret, i think the actual switch is separate and inside the handle from memory but i could be wrong here.
Older kill switches ( 1970's ) were more exposed but the contacts swiped by rotating the switch thus cleaning the surfaces every time they were used, modern switches don't have this cleaning effect and you are not the first case, just good observation on your part.
The fuel pump is a very good test for this switch like you mentioned.
  CB1100 Idle speed instability problem ericlo69_imp 1,434 113,163 07-26-2026, 01:51 AM
  idle problem update 1973cb750 37 1,882 05-12-2026, 08:38 PM
Last Post: rdprdp01
  Chain or sprocket problem ? The Gecko_imp 14 1,162 07-30-2024, 10:05 AM
  O ring chain problem Mixagon_imp 7 622 10-17-2023, 07:28 AM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 4,344 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
   2017 EX Headlight Dimmer Switch problem? sleeper_imp 24 1,748 10-08-2022, 12:27 PM
  Fast Idle Problem Solved Nachodaddy 17 1,382 10-08-2022, 09:18 AM
  Another High Idle Problem emptysea 60 3,710 07-05-2022, 11:41 AM
  Tail light install problem iamheero_imp 9 674 11-27-2021, 02:58 AM
Last Post: Bazbro_imp
  Rear indicator design problem Mixagon_imp 5 483 06-19-2021, 04:23 AM
Last Post: Mixagon_imp
