Threads: 33
Likes Given: 6
(07-11-2022, 09:23 AM)Jurlie_imp Wrote: (07-08-2022, 12:34 AM)SportsterDoc_imp Wrote: Using 1/2 quart between changes, you may want to consider 10W50, such as Castrol Power 1 RS.
Riding in the east bay area, 20W50 (easier to find) would work.
BTW 10W40 is only rated for up to 104F
I am currently using 10W50 in my Yamaha Bolt, but having difficulty getting 2 more quarts from O'Relllys for next oil change. After that, I plan to run 20W50, since, unlike Ferret, I am not likley to start a ride below 50F.
https://cb1100forum.com/forum/showthread...#pid270064
From what you say I conclude it’s better not to operate the bike with 10w50 or 20w50 if it gets colder than 50F (it’s not uncommon in the early morning in the East Bay in colder season), right?
Upd. I see, thanks.
50F is minimum recommended temp (sources may vary) for 20W50. If the bike is garaged, then a few degrees lower outside ambient should not be an issue.
10W50 is good below freezing.
This chart is from my 2018 Yamaha Bolt owner's manual, but the temperature range is the same, regardless of application.
Likes Given: 1,010
Interesting. Thanks for posting that, Doc.
Threads: 33
Likes Given: 6
BRP (CanAm) has their own oil, XPS
For 10W40, XPS states Ambient temperature operating range: -13°F / 104°F (-25°C / 40°C)
Threads: 5
(07-11-2022, 09:33 AM)SportsterDoc_imp Wrote: (07-11-2022, 09:23 AM)Jurlie_imp Wrote: (07-08-2022, 12:34 AM)SportsterDoc_imp Wrote: Using 1/2 quart between changes, you may want to consider 10W50, such as Castrol Power 1 RS.
Upd. I see, thanks.
I believe the applicability chart may vary between different bike manufacturers, as they can use different alloys for the engine and design different tolerances between the moving parts. But that more regards to the brand new engine. Anyway, for the well worn-in engine it shouldn’t be an issue.
Threads: 33
Likes Given: 6
(07-11-2022, 09:56 AM)Jurlie_imp Wrote: (07-11-2022, 09:33 AM)SportsterDoc_imp Wrote: (07-11-2022, 09:23 AM)Jurlie_imp Wrote: (07-08-2022, 12:34 AM)SportsterDoc_imp Wrote: Using 1/2 quart between changes, you may want to consider 10W50, such as Castrol Power 1 RS.
Upd. I see, thanks.
A manufacturer may recommend different viscosity ranges as appropriate for engine tolerances (or striving for more fuel economy to meet EPA standards). For example, both of my Triumphs, air cooled and watercooled specified 20W50.
However the Yamaha chart is a decent guide for viscosity versus temperature ranges.
Moto Guzzi recommended 10w60 for the V7II, which held only 2 liters, but did very well in southern Nevada
The ambient indicated in the photo is 116F at 4 PM on June 21, 2017
(07-11-2022, 09:52 AM)SportsterDoc_imp Wrote: BRP (CanAm) has their own oil, XPS
I can attest 10W40 in the CB1100 will operate normally at air ambient -25C without issue. It may chug a wee bit more at stone-cold start-up, but it will purr after the oil starvation scraping phase has been quenched with ice-cold oil.
Ultimately I ended up using 5W40 synthetic in the CB1100 lump.
Threads: 10
Likes Received: 179 in 104 posts
Likes Given: 480
As our temperature reached a record 115F today and rarely goes below 40, I think 30W50 will work in my bike. But I have 10W40 in it now and I'm not running it, so not changing it. I suspect the engineers at Honda built in a little leeway for us on this subject.
Threads: 78
Still assuming that your engine is fine, I think it is "a possibility" that your oil burn comes from borderline too high temps (for that particular oil) and relatively high rpm/s (compared to many riders taking it a little more easy). Why would this be ? A tiny amount of oil gets past the piston rings on every revolution. Two times as many revolutions per mile means two times as many times that amount. Add to this the almost too thin oil (viscosity at high temps, outside temps plus higher engine temps), not only does it no longer do its best job cooling the engine and lubricating it, it also has it slightly easier to get past the piston rings. Added all up, this could explain your data. Try different oil as proposed above, and take it a little easier on the throttle when the thermometer goes past 100F. A few months should show the difference.
Threads: 13
Likes Received: 79 in 49 posts
Likes Given: 45
i have used with success lucas upper cylinder lube to help valve guides stay lubed with todays dry gas valve guides and seal need all the help they can get maybe worth a try
Threads: 5
Thanks guys for the recommendations. Now, before the summer season I've put 10W50 Motul 7100 in it. Let's see how it goes thru summer. Now sure, I'll put my usual 4k miles during it, as I got yet another toy recently...
