TPS Sourcing because of High Idle
(05-14-2023, 05:44 AM)Nachodaddy_imp Wrote:
(05-13-2023, 11:37 AM)Obi-wan Kenobi_imp Wrote: Hello There,
My CB1100 has been experiencing high idle issues similar to other on this forum. I have spent a good amount of time reading posts hoping that someone has already figured this out for me. But I could not find someone with the exact same symptoms.
The problem I experience is that the idle RPM is about 1,500 with the clutch fully in, and the idle RPM is about 2,000 when partially out (But still dis-engaged). I have learned to ride with using two fingers to pull in the clutch. This results in my other fingers behind the clutch. When the clutch is in this position, the engine is at 2,000 RPM.
I dont think that the problem is related to the IACV because when I first start the engine it warms up at 1500 RPM and then settles at 1100 RPM. Only when I start riding does the idle never drop below 1500 RPM (clutch fully in) or 2000 RPM (clutch in with two fingers)
I think that the problem is related to the TPS because when I ride with it unplugged, the engine idles right at 1000-1100 RPM. My theory is that there is something wrong with the middle zone of the sensor. At 1500 RPM idle I get 0.5 v from the signal line, and I get 5 v on the power line.
The help I need is sourcing a new TPS. I tried cross referencing compatible part numbers and bought one for $16. That one rotated the wrong way and was no good for me. I ended up taking the OEM one off the bike, and then put it back on. Does anyone know a compatible TPS part number?
I had thought it was: 16402-REJ-W01
Compatible part numbers per random Ebay listing:
Manufacturer Part Number
16402 REJ W01, 16402 REJ 003, 16402 PWA 003
Interchange Part Number:
JT7H, JT7H20410, TPS008-03, TPS113, GEGT7610-158, 16402-RAA-A01, 16402-RAC-A01, TPS-H112, TPS-H113, JT6HB, T42002, 16402-RAA-A02, 16402-REJ-W01, T42004, 977-024, HAJT7HARK
Any other ideas are welcome. Maybe my brain is fried from thinking about this too much.
You can change out every part on this bike except the ECU and you will still have the same problem. I spent $700 to have a new IACV installed and it didn't make a bit of difference. While the smoke was clearing from burning seven hundred dollar bills, I read Power Dubs' advice to replace my ECU and a post by someone in South Korea who took his to his local shop where they replaced the ECU and the problem went away. So I bought a new one (not a used one on EBAY) and it worked fine and still does, just like Power Dubs said it would.
I cannot tell you why it did work for people who replaced the IACV, or even why it worked to change MY ECU, but it did when I changed it. I ordered a new one from Partzilla and my bike has run fine since. No, I repeat NO problems since. Yes, $478 ($500 with shipping and tax) is expensive, but so are Corbin seats and Road Comet windshields. I agree that Honda should replace it free, but they disagree.
Disconnecting the TPS puts the bike in "Limp-Home" mode, to my understanding, and allows the bike to run fine except the "check-engine" light comes on and it won't rev over 5,000 RPM. You can ride it fine that way, but it DOES NOT MEAN THAT IS THE PROBLEM.
Read my LIPS! It's the ECU!
So you go ahead and replace your TPS and IACV and waste money as long as you have it to burn, but this problem will NOT go away until you put the new ECU in.
The part number is 38770-MGC-A24.
Originally the part number was 38770-MGC-A23. The change in part number tells me that Honda found a flaw and replaced it.
Replacing yours with a used one is very likely to result in the same problem.
I wish you all the best of luck in solving this problem, but I am convinced that the ECU is the problem and I hope it works for you as it did for me.
BeerBiker
The last few years it seems that late model bike ECU firmware have been undergoing iterations of updates to combat challenges as a result of meeting the Euro 5 emission standard. Honda was also affected by it. It seems now by 2023 the dust has mostly settled as manufacturers tweaked out the ECU bugs.
Some Euro 4 bikes needed ECU firmware updates too, but thankfully for many it wasn't as a challenging as Euro 5. I cannot imagine how the next generation of bikes fair as Euro 6 puts a further stranglehold on the fuel emissions.
I sent Obi-wan Kenobi a pm because I should have asked the year and model of his bike. I did not check to see if that is the part number for his year and model ECU and I noticed the other day that someone in Canada posted a completely different pn for Canadian ECUs, so that throws a whole new light on things.
All I can say, is that replacing ECU 38770-MGC-A23 with ECU 38770-MGC-A24 on my 2013 standard got rid of the high idle problem. Maybe mapping the ECU will give us clearer answers.
From his avatar, I’m guessing Obi-wan Kenobi’s bike is a 2014 standard.
1973cb750 has a copy of my 2013 Part #38770-MGC-A23 ECU and Part #38770-MGC-A24 ECU
I did not have the high idle problem....so far.
Thanks all for the helpful replies. My bike is a 2014 Non-ABS, and I am in the U.S.
When I try to find the part on Partzilla.com I find the below part number. Does that look like what I am looking for?
PGM-FI UNIT
38770-MGC-A42
I will look into getting an new ECU. Have any of you replaced the ECU yourselves? I am pretty good with working on things, but have limited tools at my apartment. I am just wondering how difficult of a task it would be to do myself.
The hardest part of replacing the ECU is removing the tank for access. The fuel line fitting is fiddly.
Look here: https://www.partsfish.com/oemparts/a/hon...re-harness
The ECU is item 11 and has a new part number. The old one is the one you list in your post.
I honestly wouldn't spend the money on a new ECU these days.
For less than you would pay for a night out at dinner- you can buy the cable & adapter needed to read and write the ECU.
So- as long as you have a laptop or computer you can plug into the bike... you can update the software yourself with the help of 1973cb750.
Especially if he can combine the 'tuned' aspects of what I sent him with the new version of whatever the factory has.
The problem may be IACV and/or ECU/ECU program but not likely the TPS
Just glancing at pages 5-15 and 5-16 of the service manual shows how well the CB1100 will continue to perform with many sensor codes.
If the EOT is wonky, the only issue is hard starting cold.
If the IAT is wonky, default is 95 F.
If TPS is wonky, default is 0 degrees position
If an O2 sensor is wonky, "engine operates normally"
glad to see your back dubs id like to try and flash a oem ecm with the issues and see what happens
(05-14-2023, 11:54 PM)1973cb750_imp Wrote: glad to see your back dubs id like to try and flash a oem ecm with the issues and see what happens
Second thatThumbs Up
  CB1100 Idle speed instability problem ericlo69_imp 1,434 118,644 07-26-2026, 01:51 AM
  idle problem update 1973cb750 37 2,135 05-12-2026, 08:38 PM
Last Post: rdprdp01
  'Factory' high performance spark plugs PowerDubs_imp 17 1,500 10-23-2024, 02:50 PM
Last Post: rtmoto1
  Idle a little rough and miss fire when revved johnnyH_imp 3 426 09-15-2024, 12:16 AM
  High engine revs on start up CBX1000_imp 21 1,835 06-06-2024, 02:40 AM
  another idle thread Tom_imp 11 1,016 11-20-2023, 01:30 PM
  Honda CB1100 Rough Idle Solution dickie1951_imp 56 4,284 09-06-2023, 01:36 AM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 4,823 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
  High mileage and oil consumption Jurlie_imp 24 2,167 04-07-2023, 06:05 AM
  High idle mattmcuomo@yahoo.com 7 697 10-29-2022, 11:09 AM
