Running cold
(11-15-2013, 11:19 PM)sanoke_imp Wrote:
(11-15-2013, 10:21 PM)ingobohn_imp Wrote: As sanoke said, the "modern" fuel injection compensates air density (be it because of temperature or altitude).
Only "old" carburators had issues with more/less oxygen.
There might be a difference for our CB 1100 between hot and cold weather: maybe under very hot conditions the air cooling is at its limit and the fuel tends to more spontaneous combustions in the "overheated" cylinders. Just guessing...
I'll bet that's why Honda recommends 86 Octane. The compression is pretty low but being air cooled and lean due to emissions, summer heat may push it towards pre-ignition.
Ok, sure, but what if you're using full-synthetic oil instead of regular mineral oil?
(muh-ah-hah)
Officially at least in Germany, Honda recommends 92 octane. But my dealer said with a smile on his face, "with the CB 1100 it's the same like with every Honda: you can fuel it up with everything but diesel". Smile
In Germany, fuels are graded differently for octane than in the US
Ah, really? I thought the "octane grading" is worldwide the same, so 92 octane in the U.S. is of same quality as in Germany.
Ours are approved for 87 octane ( our regular) I think you dont have 87, right? And 92 is your regular.
Ah okay, now I understand. You mean the engine homologation differs from country to country or continent to continent. Yes right, 87 octane fuel is not available here in Germany. Even 92 octane fuel is nearly no longer available anymore. As there are so many different fuel types here and as at our gas stations each gas pump has more than one nozzle (one for each different sort of fuel), some pumps have 5 or 6 nozzles. So I think with Diesel, Diesel+, Super 95 E5, Super 95 E10, and Super+ most of the gas stations simply gave up serving also Benzin 92.
As a Benzin 92 engine can also operate with Super 95 this is generally no problem - despite the fact that Benzin 92 was some cents cheaper per liter. So I think the second reason to deprecate Benzin 92 at German fuel stations is simply the higher profit they can make with other type of fuels.
I fuel up my CB 1100 always with Super 95.
Besides that: Homologation for octane 86 grade would also have some side effects on emission levels, hp/torque of the engine and fuel consumption, right?
I just check the U.S. Honda website and did not find any specifications of the CB 1100 engine regarding hp/torque, I only found [url=http://powersports.honda.com/2013/cb1100/specifications.aspx]this.
With regards to hp and torque, I tend to look at dyno charts rather than mfg claims. Seems they are dynoing about 80 hp and 65 ft lbs of torque at the rear wheel
Homologation shomologation. They simply use a different formula so you get 2 different octane numbers for the same gas.... theres 2 different methods so you get 2 different numbers but they mean essentially the same thing.
(11-16-2013, 11:15 PM)ingobohn_imp Wrote: Ah, really? I thought the "octane grading" is worldwide the same, so 92 octane in the U.S. is of same quality as in Germany.
octane is not a worldwide standard. My 92 is higher octane than your 92 because the arithmetic is different.
Hmm, now I am puzzled... I know that Wikipedia is not THE truth both they say that the octane rating and especially the RON (this is the number which is referred to) is a worldwide standard.
Of course now it could be that US numbers at gas pumps do not state the RON but something different.
  Cold Weather Riding Yata-Garasu_imp 79 6,951 01-24-2026, 12:21 PM
  Anyone running Pirelli Scorpion STR on the CB, or any other semi knobbie? tod.branko_imp 4 449 12-24-2020, 02:20 AM
Last Post: jedd_imp
  Everything is running well - then the weather turns bad ohiorider_imp 11 1,097 11-02-2018, 12:02 PM
Last Post: ohiorider_imp
  Anybody running a pulser headlight,brake light module? FLYTYM_imp 8 561 06-06-2018, 01:12 PM
Last Post: FLYTYM_imp
  CB Cold Weather Start-Up Haystack_imp 18 1,124 01-24-2016, 03:17 AM
Last Post: Rocky_imp
  Anybody running the Samurider low bars? Griso Guy_imp 14 897 04-16-2015, 04:22 AM
  Running out of clearance kevbroce_imp 11 779 09-10-2014, 06:06 AM
Last Post: AzBob_imp
  10W40 and cold weather retroman_imp 12 757 10-21-2013, 04:56 AM
Last Post: meowguy_imp
  How cold will you ride? HikerToo_imp 31 1,778 09-02-2013, 06:02 AM
