10W40 and cold weather
Hi,
I used 10w40 for the 600m oil change since the dealer was out of 10w30 and recommended 10w40 instead. The last couple of times I took the bike out for a spin in mid 40s temp I noticed louder than usual valve clicking (almost small knocks) sound from bottom front right corner of the engine, I also noticed rough idling and jerkiness (RPM fluctuations) during first few minutes or few miles of riding. Once the engine warmed up it was back to it's normal smooth self. Didn't realize that switching to 10w40 would make such a difference in cold temperatures. I don't plan on riding much longer in colder temperatures and thought I'd share this anyway to see if anyone else has any such experience or input.
Thanks,
Nooooooooooooooo
I did the exact same thing, and wouldn't worry about it. Apparently 10/40 is okay by the service manual (even though the owner's manual doesn't mention it), but it should be perfectly fine for most riding. Go back to 10/30 at the 4,000 mile oil change if it makes you more comfortable; that's what I'll do.
At start up 10/30 and 10/40 are the same viscosity.....10.
and if you use synthetic, extreme temps have less affect in the oil too.
http://www.youtube.com/watch?v=yPuMB-FPSa0
I accidentally put 10/40 in at my 4000 service. I have not seen any negative results, or heard any strange noises. When I change it next I'll go back to the 10/30 for winter and spring only because the manual calls for it and I use what the manual calls for in all my Hondas.
Once engine reaches operating temperature viscosity will be about the same on multi-viscosity oil.
Here in south Texas I use 10/40 all the time, in winter I just let it warm up abit longer or drive kinda slow for a few blocks...............and besides I don't ride when its really cold.
If you check the oil chart in the Shop Manual you can see 10/30 is good for about 15 to 55F degrees.
Quote: in the Shop Manual you can see 10/30 is good for about 15 to 55F degrees.
Here we go again. You will have to tell me how to read this chart because it makes no sense to me. For 10W30 you are saying maximum is 55 F? 85 F would be more like it.
meowguy..I think that is saying either 10w30 or 10w40 is good from 15 to 100+ ..but that is just my take on it
the chart leaves a lot to be desired.........I suppose they mean to look what temps fall below 10/30 and what falls below 10/40.........so this is telling me Honda people aren't too worried about it. On older CB's they have this chart in Owners Manual and they have specific arrows for each viscosities.
  Cold Weather Riding Yata-Garasu_imp 79 7,211 01-24-2026, 12:21 PM
  Best Weather App for riding? ymtnpoah11_imp 22 1,509 02-04-2023, 03:32 AM
  Massive weather front lashes eastern Australia Rocky_imp 15 1,184 03-23-2021, 06:49 AM
  Unusual day weather wise here in NE Ohio ohiorider_imp 4 518 12-02-2018, 11:41 PM
  Everything is running well - then the weather turns bad ohiorider_imp 11 1,100 11-02-2018, 12:02 PM
Last Post: ohiorider_imp
  Come on weather ... cooperate! ohiorider_imp 8 613 03-06-2017, 11:29 AM
  Bad weather = no seat time. SCCBrider_imp 12 950 04-14-2016, 05:41 PM
  CB Cold Weather Start-Up Haystack_imp 18 1,128 01-24-2016, 03:17 AM
Last Post: Rocky_imp
  All-weather riders: protecting your bike? alphonsus_imp 12 780 10-20-2015, 03:23 AM
Last Post: aschem_imp
  Rally Weather Powerdogg55 18 1,061 05-26-2015, 10:05 AM
