Bar End Weights?
Mine both turn freely and have since day 1
Hold the weight as tight as you can, a nylon strap wrench works great, and tighten the phillips screw as tight as you can.
The weight will always turn but the screw should never be loose.
If the screw is not tight the weight will eventually fall of. Just imagine the damage that could cause to the vehicle following you.
Information Need original 2013-14 Handlebar with weights HondaLou 5 333 08-13-2026, 06:16 PM
Last Post: HondaLou
  bar weights casey66_imp 9 879 06-08-2022, 10:41 PM
  Bar End Weights bvictory_imp 4 457 05-24-2021, 01:52 AM
  Friendly reminder: this bike weights A LOT franov_imp 15 1,819 04-17-2021, 02:29 PM
Last Post: Whoops
  A question about wheel weights. FLYTYM_imp 24 2,128 12-01-2018, 03:55 AM
Last Post: Jim21680_imp
  Handlebar end weights lash_imp 9 662 06-06-2015, 04:29 AM
Last Post: kennyw
