05-07-2022, 04:46 AM
Boy,what a pain these little dudes are. Or course I had to tear one up before I got it figured out. Should have looked it up first
bar weights
05-14-2022, 03:26 AM
I have one on the right, and none on the left. Can''t tell the difference.
05-14-2022, 09:49 PM
I couldn't find any flush bar ends. I made these . 11/16 alum bar and 3/16 fender washer.
05-14-2022, 10:32 PM
Looks good Casey!
05-15-2022, 01:10 AM
05-21-2022, 01:21 AM
05-21-2022, 03:44 AM
(05-21-2022, 01:21 AM)Charlie Bravo_imp Wrote:(05-14-2022, 09:49 PM)casey66_imp Wrote: I couldn't find any flush bar ends. I made these . 11/16 alum bar and 3/16 fender washer. When the purpose is to add weight and mass, why would you go with aluminum? Looks great, tho. And the weights are designed so that they only contact the bar through some pretty flexible rubber, and part of the weight is deep inside the bar. The idea is that they will absorb/dampen the bars vibration. More rigidly mounted weights will simply make it worse.
06-08-2022, 09:41 AM
Is there a way to make the bar weights a little more resistant to rotation?
My left side weight has unwound itself nearly a full inch just riding around. 2014 Std 6 speed
06-08-2022, 11:13 AM
The part inside the handle bar should not come out. There is a clip that holds it. If the bar end weight screw is backing out it needs thread locker on it. The OEM screw is an ALOC screw. That means is has a pre-applied locker on it. If you remove it you must add your own locker or buy another screw from Honda.
06-08-2022, 10:41 PM
For that said screw, I used liquid gasket maker and let it sit overnight to cure. Never failed yet.
« Next Oldest | Next Newest »
Need original 2013-14 Handlebar with weights | HondaLou | 5 | 213 |
Yesterday, 06:16 PM Last Post: HondaLou |
| Bar End Weights | bvictory_imp | 4 | 406 |
05-24-2021, 01:52 AM Last Post: Charlie Bravo_imp |
| Friendly reminder: this bike weights A LOT | franov_imp | 15 | 1,647 |
04-17-2021, 02:29 PM Last Post: Whoops |
| A question about wheel weights. | FLYTYM_imp | 24 | 1,907 |
12-01-2018, 03:55 AM Last Post: Jim21680_imp |
| Handlebar end weights | lash_imp | 9 | 605 |
06-06-2015, 04:29 AM Last Post: kennyw |
| Bar End Weights? | DGShannon_imp | 11 | 737 |
10-30-2014, 09:58 AM Last Post: Kai Ju_imp |
